Old 01-31-2009, 10:27 PM
log1call log1call is offline
Re: HELP!!! It's my car man. My car!!!
Some models have it in the kick panel, some have it in the dash, some have both Harvey.
He said he had already looked in the kick panel and it wasn't there.... It would be a good idea to look under the dash.
Old 01-31-2009, 10:32 PM
No US SVX has the check pins under the dash, they were all in the kick panel. All they do is ground the pin they are to be plugged into. If you have a hard time finding them, use some spare wire to create an alternate ground and push the other end into the respective socket to read the codes
Old 02-01-2009, 08:18 AM
boipeba boipeba is offline
As far as your car not idling when it's cold, The coolant sensor is the problem I think. I had the same problem on my 95, and replaced it and it starts right up. Senor is around $20.00 easy to replace as well.
boi
Old 02-01-2009, 09:38 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by jcimos View Post
I just got my car less then three months ago. Its a 94 lsi with a 5 speed tranny swap. The car needed some TLC, but i thought it was something that i couldn't handle. I WAS SO WRONG!!! Believe it or not the car doesn't have a OB I port.
1.) It doesn't idle until it warms up
2.) It misfires when i accelerate
3.) Power in acceleration is not consestant
PLEASE if anyone has an idea on whats going on please let me know.
Possibilities: Defective cam sensor, defective coolant temp sensor (as mentioned), defective coil, timing belt installed wrong or jumped teeth, defective crankshaft position sensor, defective mass airflow sensor, major vacuum leak, bad fuel pressure regulator, car just feels like being a jerk, etc.
Check the easiest things first... do you know how to use a multimeter?
Old 02-02-2009, 09:42 PM
jcimos's Avatar
jcimos jcimos is offline
Well, how do you exactly ground the wires Toms? I don't make more trouble for myself. Yes I do have a multimeter, what do you suggest I do with it? Here are some pic of the wiring setup here the link.
1.) http://i127.photobucket.com/albums/p...s/IMG_3842.jpg
2.) http://i127.photobucket.com/albums/p...s/IMG_3849.jpg
Old 02-02-2009, 09:55 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Everything you need I can see in your pics......
Heres the step by step with pics..... in PDF frmat.
http://www.subaru-svx.net/photos/files/How-To/33055.pdf
Its the biggest black connector, you ground it with either of the two blue-insulated wires that have the flat metal prongs, inserted into the top second-to-left hole (tab side up). This will make your "check engine" light flash the codes stored.
Old 02-03-2009, 08:13 AM
It is the smallest black connector pictured in your pics. You can simply touch a wire to ground while the other end is inserted into the correct pin or fin the wires that are tucked into the kick panel.
Old 02-03-2009, 09:23 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Oops I mean the mid-size one , not the little square one. If you accidentally ground the wrong connector your oil dipstick pops out and your waterpump seizes
Old 02-03-2009, 11:09 PM
jcimos's Avatar
OMG!!!!! Why didn't you say that before. LoL, just kidding. The link worked out great. Thank for the input everyone. Code number 23 seemed to be the only code. Mass airflow sensor seeems to be the problem. The former owner did a crappy job in the wiring for the connector. Does anyone know where i can get the connector and pig tail from?
