Old 03-21-2012, 12:31 PM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
Is the stock tailpipe stainless steel?
I want to add a small piece of flex pipe in the tail pipe right after my 2-to-1 stock cat.
The flex bolts rusted away and I bolted the flange right to the cat with straight bolts, so the system lost a bit of flex and it's putting some stress on the tailpipe-muffler joint.
Anyway, my question is, is the tailpipe stainless steel? It certainly does not look like it.
Will this work to cut it?
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
Also, got the SVX out after being on jackstands in the garage for 10 months. Ran perfectly!
Except, of course, the exhaust.
Old 03-21-2012, 12:34 PM
Re: Is the stock tailpipe stainless steel?
Yes.........
even stainless can rust when it is paired with steel....
Old 03-21-2012, 12:52 PM
Why don't you just go get the correct Subaru parts?
Two 44059AA010 bolts
Two 902350004 nuts
Two 44028PA000 springs
Old 03-21-2012, 01:10 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
any idea on cost ? for the above parts ?
Old 03-21-2012, 01:27 PM
About $8.00 for the pair of bolts,
about $2.00 for the nuts,
about $16.00 for the springs IF they are missing, or if you had to cut them to get it apart.
Normally those springs last forever, unless they are damaged.
Old 03-21-2012, 01:59 PM
Green1995SVX's Avatar
I've found that honda spring bolts are an exact match for ours, and are available aftermarket for just $2.42 a pair for the entire bolt/nut/spring set. Just a tip!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-21-2012, 03:25 PM
greggbzz's Avatar
Awitha Cheese-ahhh!
Two 902350004 nuts
I'll take another look, but I think the flange was so rusted and the gasket to, that the only way I could get it to stop leaking was to bolt it in there all the way.
Old 03-21-2012, 03:58 PM
they make a two piece collar flange that you can install around the original if yours is too rusty. it's just two curved pieces that the bolts go through.
Old 03-21-2012, 04:19 PM
Mike, any chance you know the part numbers, or the year and model?
Old 03-21-2012, 05:21 PM
2000 civic, or many other years, and models too I would imagine.
Old 03-21-2012, 06:08 PM
Thanks Nate.
I will buy a pair and check them out.
Old 03-21-2012, 07:57 PM
Thanks Nate.
We used them on an outback here and they worked perfect. Compared them directly to SVX bolts as well. Though not identical, they work perfectly
