FS - 1992 SVX LS-L Claret daily driver PA
Year: 1992
Trim:Subaru SVX LS-L Drive: AWD Color: Claret VIN: JF1CX3536NH103984 Manufacture Date: 07/91 Current Mileage: 224,xxx miles Location: Liverpool PA Price - $1000 - PA registered and inspected to 8/15. Contact- PM or email mckchr67@gmail.com Selling as a winter beater/daily driver or project car. Purchased recently from 2nd owner (co-worker that purchased it in 93 with ~20k miles). Car is rough looking, but motor and transmission were serviced regularly and work well. New rear window, decent rainex wiper blades. New rear side window clips. New rotors and pads 3k ago and rear calipers serviced, front exhaust/cats replaced in 2009/2010 and timing belt service done at same time. Radio and speakers work. HVAC blower and heat works, haven't tested rear defroster. Sanded and clear coated headlight lenses. A/S tires are getting old and are approximately half tread. Has under seat storage tray and owners manuals. Has inflated spare tire and factory jack. Bad/quirks - AC doesn't work. Car sat for 2 years with rear window broke out with plastic and tarp over it (all wiring is good and no water damage as I pulled the seats and carpet to check). Paint is terrible on top sides and wheels, drivers front fender has damage from getting backed into about 10 years ago (have spare fender in red), and missing interior rear shelf trim as seen in photo. Sunroof frame is rusted and I filled a hole with RVT and it doesn't leak. Leather is real rough in rear and average in front. Sun visors are removed due to not staying up. Left rear abs sensor is coding even after cleaned. Drivers seat electrics work, but have worn contacts and recline is hot wired without resistor board so it is a set and forget as motor will wear out if regularly used. Need to press shift lock to move from park. See below for highlights, car was rained on and wiped off. Full album - https://flic.kr/s/aHsjYAun1Q
Chris 2011 JSW TDI 1990 e34 beater 1992 SVX - sold Last edited by Mckchr67; 09-13-2014 at 09:56 AM. Reason: Added info |
Re: FS - 1992 SVX LS-L Claret daily driver PA
Ouch
I have 6/91, and it's now near 300K. I hope you find a buyer, as it looks like it might not survive much longer.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
If someone buys this, there is a full beautiful interior at a pick-n-pull near me. If you can find a claret with decent paint just replace the hood and fenders and you have a decent restoration project on the cheap. On the plus side the rusty parts are either replaceable or difficult to see, aka: rear quarters look good. GLWS
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 07-14-2014 at 07:03 PM. |
Thanks for the heads up on the local interior. Other than the sunroof frame and the fender damage the body is pretty decent in terms of rust. Yesterday and today were its first it has been outside in rain since my ownership and I'm going to replace the tail light gaskets and seal up the grey panels under the tail lights as they were all leaking. No leaks from rear window or sunroof.
Chris 2011 JSW TDI 1990 e34 beater 1992 SVX - sold |
Got the car registered and a plate on it. I have put some miles on the car and I'm going to put new front sway bar links on it and it will be inspected on 8/1. If some one in PA wants a cheap inspected car I'm open to offers. Share with friends. Thanks.
Seen a lot worse for a lot more asking price. New fender, paint hood. And the interior can be redone for $500/ 700 or replaced with a used set. Sun roof would be only concern. For under $3,000 you would have a decent SVX
Pa inspected to 8/15 and a fresh oil change. Price drop to $1000.
Damn I wish I had extra money. This would make a PERFECT winter beater...
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Good luck with the sale. She has alot more miles left.
Put almost 1000 miles on the car since owning it.. Oil is pushing through most seals with typical 225k and with crazy rain the trunk is still leaking from some where after doing the tail lights.... Price drop to $800 obo.. Would like to move it soon to make room before fall.
Is that a stock transmission? At what mileage was it last replaced? How does it drive on the highway? I've been considering selling my daily driver to get out of the monthly payments.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 Last edited by Sean486; 08-16-2014 at 10:30 AM. |
Stock transmission was replaced at ~160k with a ~38k stock unit from a newer year, replaced around early 2000's, PO told me that he had the transmission serviced about every 40k. It drives pretty good on the highway. I have been running at 65 on cruise. I'm going to do the trunk seal this week as some water was coming in around it.
Chris 2011 JSW TDI 1990 e34 beater 1992 SVX - sold Last edited by Mckchr67; 09-11-2014 at 04:11 PM. Reason: Updated added corrected info |
Updated my false/misunderstood text information from PO. Spoke with him at work when he brought me the spare key today and trans was replaced as noted above. If you want to check it out I can meet up on east or west shore... I work up over the hill from the farm show complex.
Chris 2011 JSW TDI 1990 e34 beater 1992 SVX - sold Last edited by Mckchr67; 08-21-2014 at 08:47 PM. |
$700 obo would like to see this gone so it doesn't sit around over the winter.
I would, but it's just too far for me to take the chance. I hope it moves for you soon. I would hate to see it lost...
