#451
Re: Wheels that fit the SVX
I'm looking at some Enkei EKM3 rims, does anybody know if some 17x7 rims with +45 offset will fit? also does anybody have any suggestion for tire sizes?
#452
Yes, that should fit just fine.
225/45 is close to stock diameter. You could also use 215/45 or 215/50. Anything wider than 225 is not recommended on a 7" wide rim. On a 7.5 you can get away with a 235 width, and on an 8" wide rim, you can run 245s, though there may be some rubbing depending on offset and suspension setup.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#453
Thanks for your help!
#454
found another cool cross over 18" wheel
Im going to try on the SVX... details soon to come
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
#455
* munches on popcorn while waiting with quiet anticipation * |
#456
I have a pic of the wheel
but waiting to put them on the car first and take some pics. I have 2 Svxs Im restoring/fixing back up some to get ready to prob sell in the Spring time.. 1 is a 5 spd conv.
#457
Going to be trying a "little" something on my car when I go to see it in March...
What size you ask? I only bought one wheel, managed to snag it at a great price on Nasioc. If it fits then I'll complete the set. If it doesn't I'll make it into furniture.
#458
looks good, other then the 9.5 width I dont forsee problems.
but I dont know if that offset, looks like it may be 38 will cause issues. |
#459
Just got these still have not been able to take better pic's but here they are
18x8 48 offset with 225/40/18's |
#460
My BBS wheels are 8" wide, +53 offset. The Grid is 1.5" wider, so 0.75" farther out inside and outside. 0.75" = 19.05mm reduced clearance to the strut on the inside. The 15mm difference in offset brings that down to 4.05mm additional inward width. Long story short, body work can be massaged to fit larger wheels. Struts don't move. And I know I have maybe 1cm of clearance from wheel to strut as is.
#461
Price $150
Size 18x7.5 Offset +45mm Brand of wheel Mazda CX-7 Name of wheel 23lbs. Who sells the wheel Mazda I just scored these take-offs on craigslist for $150. They have less than 10k on them and are in perfect condition (just dirty) I should make my money back on selling the Bridgestone tires that are currently on the rims. Am I the only one with these CX-7 wheels? And what's the best tire size for these? 235/40? Can't wait to get these on the car!
-Brian Current fleet: 89 D21 2wd 91 XT6 93 D21 4wd 95 SVX LSi 02 Windstar Sport 03 CL500 03 Avalanche NF 07 RDX 08 Outback 10 Outback 10 Murano 12 Accent 15 STi |
#463
Or if you can find some 245/35/18 but those are more expensive and harder to find. |
#464
Hello,
Last year, I installed new wheels on my svx. Front: 19x8.5 Rear 19x9.5. With 245/35 front and 275/30 rear tires. Now, I have problems with the drive train. My drive shaft and center diff suffered, because the rolling circumference between front and rear has a difference of 20 milimeters. Would it work, if I use 235/35 tires instead of 245's, so that the rolling circumference difference falls to 1 mm? Or could it be, that the svx cant handle the different wheel/tire sizes between front and rear? Greetings |
#465
Because of the AWD system, running a "staggered" fitment is not recommended. 1mm difference should be within acceptable limits, but it's still not worth the hassle IMO. It doesn't help performance, so if the looks are worth borking your drivetrain, go for it. Or, you could get a FWD model, which will handle it fine. You could also have it converted to FWD and sell your parts to someone wanting to go FWD --> AWD.
