major electric malfunction
My SVX was hit this year by unfortunate chain of events.
First some one busted my windshield,i was able to buy new one but it was damaged in transport. Couuple weeks ago i finaly got another one for free from member of this forum. Last month i got flat tire while driving 65mph in pretty dense traffic.It was raining and for some reason my flashers did not work,but my turn signals worked fine.So i had to get set of 2 new tires(other 2 have90% left). When puting spare on i broke one of whell studs.On my way back from tire shop i got "christmas tree lights "on dashboard.I had to go another 15 miles to auto parts store to test my alternator.It was bad ,almost dead. I ordered a new one and headed home,another 5 miles.Car bearly made it.My battery exploded and acid spiled on my parking lot but i had to pusch my car in to parking space.I ordered new battery. Last saturday i finaly had time to put new alternator,belt and battery in.I had to replace some 10 blown fuses under the hood and behind driver kick panel. I fired the car and it worked fine for minute or two then dark red/brown smoke started comming from under the steering column inside of the car. I didnt have time to check if everything was working when it was running. After shutting her down i had to replace 10Afuse for clock in main fuse box and 20A for front wipers in kick panel. 10 A was replaced and does not blow off now 20A keeps blowing off immidietly after starting the car. Here is how my car works now(or does not work): -engine starts ,revs and works no hesitation. -all external lights work(hi low fog park) -no turn signals or flashers -center over head panel lights don't work -sun visor lights work -sun roof works -clock does not work -radio works -cd player does not work -cigaret lighter works -dash illumination does not work -ac /heat/fan works -cruise control does not work -ABS light stays on -AIR BAG light stays on -rear wiper and splasher works -front wiper does not work -front splasher works -wiper winter position swich does not work -automatic seat belts work -all windows work -remote mirrors work - central door lock does not work power steering does not work power brakes works. I removed panel under stering column and looked there hopeing to se something obvious but could not see nothing. Any ideas or sugestions? I know nothing about electricity. I,m sending pm's to OT and YT,maybe they can help. If not i will put it in shop and hope they not gonna ripe me off! I need my car for READING meet!!! MY car is 1992 lsl 118k 5mt. - Last edited by SVXBart; 03-18-2008 at 08:35 PM. |
Bart, sounds like the regulator in your alternator was bad and overcharged the system... Thus the fried battery and several fuses... BUT what surprises me is that the fusibe link did not burn out first.
Anyway, I would have to see the car to help at all... If you can come up on Saturday I could look at it then... Otherwise... I cannot tell you much without seeing it... Basically there is a wire that burned up and it shorting out a lot fo stuff right now.... We need to find it/them Tom |
I agree with Tom. Another member had a very similar fault, alternator voltage regulator failure, not long ago. A search may turn it up if you are interested in the details.
You advise that you know nothing about electricity. You have a rather serious and complicated problem. It would be pointless trying to guide you through fault finding procedures, as we would all wind up quite mad. However rest assured that we do commiserate.
Hi Bart.
I just saw this now.
Maybe Di and I can stop in on Friday on our way to YTs place. I'll speak with her in the morning. Tom
So Sorry....
It sounds like you may be in a bunch of trouble.
The things that don’t work do not have a common electrical supply but several fuses are involved. The fuse link of ciurse is a common supply but obviously it now is ok since you replaced it and several things are working. Is it possible that you still have some bad fuses? There are the 2 fuse boxes, as I am sure you know. If you are acyually testing the fuses instead of just visually looking at them, you will know if there are some bad ones. If all fuses are good, you may have some serious component failiers because of< Lord only knows, how much voltage went through the system. Obviously enough to destroy the battery. Sure sounds like a serious one for you. So sorry… Maybe we should put our heads together and try to come up with an addition to the system that would protect against that drastic regulator failure. |
Fixored... I have just about everything fixed with replacement of numerour relays and control units. Most surprising of them being the power steering control unit(was literally smoking from a fried capacitor it looked like). Only things I need to work on are the ABS module (i just need to put a good one in) and the climate control display(doesn't light up). Other than that, it all works. Something else that surprised me, the door locks. Since the 92's didn't have central locking, the lock/unlock switch is the driver's door lock. Both door lock actuators had their contacts welded shut in the lock position. i have to replace BOTH actuators!! Also the door lock timer and then time control module.... You get the picture... It wasn't easy to find this stuff but with my service manuals and my mitchell disc it was much easier to trace the power distribution to know what to look for
Tom |
WOW!!!
Its sounds like ALL the magic smoke was let out of this one! Kudos to you Tom.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
I should also thank OT who did initial repair on power sterring on his way to NJ meet.He also brought back Good ABS unit from that meet, on his way back and offered to work on my car at 11pm suon sunday!
THANKS OT!!! THANKS DI !!! |
