#106
interesting.... I only have an under hood FP guage, cant quote you my FP #'s, but my car idles at 14.6-15.0, and cruises at this as well, 600rpm(i dont know if your belt driven blower may cuase irratics?) I have dropped down to 10.9-11.4:1 afr at full throttle. I have the FPR seeing boost off the stock location on the manifold. phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#107
It some times at lower boost pressures (below 2psi) reads 0, and does not kick up to next higher # untill it is fully there. Like when the analog reads 4.9 or so the digital still reads 4psi.
#108
the only reason I suggested it was he was runng far too richg with it connected. This was a temp solution to see if it would help
Tom |
#109
I forgot to tell you Tom, I got my MOMO knob to fit pretty good. I had the bottom machined off and the set screws moved up. the knob sits about 3/4 inch lower then what it use too. It is much more comfortable now. I must be insane having a $80 shift knob machined down to fit my car!
#110
if I have time on Thursday I will cut and weld my extra shifter for ya to lower it another 1.5"
Tom |
#111
Svxfiles 0-60mph vid w/ afr & boost
#112
#113
#114
I think he is pretty damn close to what the G tech said. I was timing the run on the counter for realplayer and assuming he let off at 60 or just over, it was in the low 5 second range. Way to go Tom!
P.S. Is the Magnaflow ready for Road Demon yet?? 72 hours to go and I'll be at Reading!! |
#115
Did you see the one comment posted? Quote:
#116
I've also been kicking svxfiles in the butt to get his car to the dragstrip. Temps are only going to get warmer - and it'll be interesting to see how she does in 60-70* weather. With the 4.44 final drive and shorter-than-stock ratios of the first two gears (3.207 & 1.619 vs 2.785 & 1.545) and then the big fall-off to the 1.000 third gear ratio, I'm guessing Tom should run a very low 14 @ 99-100mph. If he had a 5/6MT, he would be even faster.
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 04-18-2006 at 03:01 PM. |
#117
WOW
The sound is ridiculous.... I cannot wait until school is over and money is a little more loose
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#118
Awesome video. They should have come with boost from the factory
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#119
#120
he did drop to 11.4-1 at about 6lbs in 1st gear if you look closely then it spiked to about 14 at 8lbs.
Tom |
