need info to replace MAF
Can anyone provide instruction/photo of where the MAF sensor is located and how to remove/replace it? I need to replace the one in my 94 SVX and think I know where it's located (in the intake air after the box from the passenger side fender? but I'd like to make sure and see a photo if possible and although it looks straight forward, know if there are any tricks. Thanks
Re: need info to replace MAF
if you look in the how to section there is a write up about re soldering the maf with pictures. might want to try that before you replace it.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
It's the cylinder with a square block and electrical connector coming out of the airbox.
Pop the 4 tabs holding the airbox closed, loosen the strap clamp holding the intake hose the to back end of the MAF and unplug the connector. Lift the top of the airbox and slide the whole thing apart from the hose. Inside the airbox lid are 4 10mm bolts. Remove these and the MAF falls off. The bracket inside the airbox will also fall out, just put it back where it belongs when you install the new one. No tricks, no fancy tools. If you can't figure it out as you go then you really shouldn't be holding a wrench.
Sounds like I can handle that. I'll also check the how to section before I start. Thanks.
