Old 07-31-2008, 09:14 AM
Transmission and radiator temps.
Fun With Numbers
I had an SVX on the lift this morning with the thermostat removed to circulate a radiator flush and took these digital readings all within a few minutes, after the car was running for about ten minutes.
The dash temperature gauge showed ¼.
Trans pan--------------------------107°f-----106°f
Trans out line-----------------------137°f-----129°f
Trans return line--------------------129°f-----124°f
SSM Water temp--------------------145°f-----144°f
SSM Trans temp---------------------91°f -----95°f
Bottom of head---------------------144°f-----145°f
Header with shield removed----------346°f-----346°f
Bottom of radiator-------------------122°f-----118°f
Lower hose-------------------------119°f-----117°f
Upper hose-------------------------124°f-----120°f
Top of engine block-----------------128°f-----133°f
Upper intake manifold---------------100°f------98°f
Note; Silla radiator, AC on, garage temp 80°f.
Old 07-31-2008, 09:34 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Transmission and radiator temps.
Trans pan--------------------------167°f
These are the ones that make me curious... When was the car driven, and how much before it went on the lift for the flush? Or are these tranny temps just from pulling into the shop and running in Park?
What do you see as the reason for the 30* difference in the pan temp? Is it possibal that it's due to heat radiated from the Y pipes?
And then another ~40* difference to the SSM Trans temp???
On the inlet and outlet temps were you shooting the metal line or rubber line?
And the biggest question I have is how do you type a degree sign??????
Old 07-31-2008, 09:46 AM
Maxo's Avatar
Maxo Maxo is offline
Alt + 248(on the num pad) = °
Old 07-31-2008, 11:05 AM
legacyau legacyau is offline
you say thermstat removed so it could be running cooler than it should ?
Old 07-31-2008, 11:49 AM
Oops!
The 167°f was a typo!
The rest of the numbers are (now) correct.
The car was not driven, just started and allowed to warm up on the lift in park.
On the inlet and return lines I was shooting at the metal lines.
Hold "alt" 0176
Old 07-31-2008, 11:50 AM
Yes, and later I'll run it again with a factory thermostat.
Old 07-31-2008, 01:10 PM
dromano's Avatar
dromano dromano is offline
Originally Posted by Maxo View Post
Alt + 248 = °
Doesn't work on Windows XP Home Ed.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 07-31-2008, 01:32 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Tom is this my car your playing with again
1995 POLO LSI 76K MILES SOLD
Old 07-31-2008, 05:18 PM
Playing with?! It's all I do, Wake up, work on Dans car...
Go to sleep, dream about working on Dans car...
Wake up and sleep/work on Dans car...
The only good news is that I have been charging $35.00 an hour since 2007.
Old 08-01-2008, 09:32 AM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
[COLOR="Red"]
° = Hold "alt" + 0176 (on numbers pad)
Once you know the ASCII codes, you can put all kinds of nifty symbols in your posts. I use Ø all the time at work (Alt + 0216).
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 08-01-2008, 10:57 AM
dcarrb dcarrb is offline
Option>k on a Mac.˚
dcb
