Old 04-29-2008, 06:08 PM
dennyo dennyo is offline
Question checking codes
Wondering if someone can help.I recently got a cel and following the how to to check codes, I took off the cover, found the 2 blue wires but the black connector doesn't have a wire to the 2nd hole on top left side it has an orange wire in the first socket.I also found tucked under the carpet a female connector that would mate to the other. This one has a foam cover on it and only has one wire to it(black).Should I be tapping the orange wire for code and should these be reconnected when done? Anyone run into this before? the car is a 96 lsi I can't tell what color wire goes to the 2nd socket from the photos
Old 09-20-2008, 11:21 AM
nazgul nazgul is offline
Send a message via AIM to nazgul Send a message via Skype™ to nazgul
Question Re: checking codes (wires don't match instructions)
I am exactly where you are, did you ever find an answer?
The black box has no contact in the second-from the left opening. There *is* a separate wire taped up with a female connector on it, but if I stick the blue wire in that all that happens is that the right "door-open" connect goes on.
See the attached picture. Thanks!
Old 09-21-2008, 11:10 AM
Re: checking codes
I don't know which file you looked at, but if you click here, you will see you have everything you need to check the codes. If you have already seen it, read it again. Good luck.
Old 09-21-2008, 12:25 PM
Re: checking codes
Since both of you are trying to check codes on 1996 OBDII cars, why are you not using a code reader to plug into the diagnostic connector to the right of the steering wheel?
OBDII Code readers are inexpensive and allow you to clear the codes as well.
Old 09-21-2008, 01:07 PM
Re: checking codes
That one. If you look at those pictures, you'll see that there is a contact in the second slot where you insert the blue cable. There is no contact in mine.
So the older cars didn't have the connector? That may be the explanation then. When they added the connector perhaps they removed the diagnostic backdoor.
Up until now I've had very few reasons to want one, but given the age of the car, I guess it's time I got one. Unfortunately right now I'm 200 miles from home. Hopefully whatever is wrong will wait until I get back.
Thanks.
Old 09-21-2008, 04:20 PM
Re: checking codes
I didn't know that you both had 96s. That would have helped a lot.
Old 09-21-2008, 06:05 PM
Re: checking codes
The OBDII cars (1996-1997) have the diagnostic connector in the lower dash, to the right of the steering wheel.
This is the same location that was occupied by the coin holder in the earlier OBDI cars (1992-1995)
Old 09-22-2008, 07:24 AM
Re: checking codes
thanks to all who replied. I had almost forgotten this post.I did buy a actron scanner a few months ago and it has saved me a bag of money on repairs.Thanks again dennis
