Question about subaruparts.com gasket kit
Anyone have experience withe this kit part# 10105AA060? My main question is does it come with items like valve cover gaskets, cam seals, main seals, oil pump, etc.. My car recently decided it want's to do it's best impression of the Exxon Valdez (lost 3 quarts in 200 miles) so it is time to pull the motor and reseal it. Most of the leaks seem to be valve covers and either rear main or oil seperator, but I figure on doing the seals, timing belt and water pump and being done with it for a while..
92 Teal 181K 4:11 trans Lightweight crank pulley Redline Shockproof Trans Cooler Viper 550 HF Alarm/Remote Start 18" Enkei Evo5's |
Re: Question about subaruparts.com gasket kit
No oil pump but all gaskets and oil seals are included including the 20 washer gaskets for the valve covers. Timing belt and water pump are separate but a good idea to replace as well. Might want to do the thermostat as well while you have easy access and thats only a few bucks more.
If you do, make sure you buy a thermostat gasket. The kit doesn't come with one. It also doesn't include the 4 half moon seals at the rear of the valve covers, which I had to buy separately.
I figured the thermostat would come with a new gasket, however I forgot about those extra valve cover seals.
I just got a subaru engine reseal kit from subaruparts.com, and it did NOT come with any valve cover gaskets. Might wanna check on that in this kit. I emailed the guys at subaruparts.com and got a parts list of the gaskets that came in the kit. They got me the list right away.
Mine came with all of the valve cover gaskets.
The full list of items is 50 different types of seals, many of which are multiple items. There are probably over 100 items in the kit all together.
My kit was for a '99 Legacy 2.5 DOHC, and it did not come with the VC gaskets. I am not sure of the kit for the SVX. Here is a copy of what mine came with.
Enjoy Paul |
I would email subaruparts.com, and they will give you a list of what that kit contains. That's how I got the list I just posted for the Legacy.
