What's the point of buying a pwr radiator?
Say the stock one works perfectly, and the car never overheats. Would buying a pwr radiator make sense for a daily-driven non-racecar? Even if it does keep the engine cooler, won't the thermostat make it run at a certain operating temp anyways?
Brian |
I don't have one but think all-metal construction is the biggest selling point. There's no plastic tank to split.
dcb |
svx radiators spontaneously split open?
Brian |
From what I've seen the plastic tanks aren't exactly "Lifetime warranteed".
My teal came with a conveniently pre-split top tank when I bought it at <105,000 miles. Judging from the posts I've read, this could be the most common of all SVX afflictions.
dcb |
Mine did about 2 months ago (with 131k miles on her). All of a sudden.. smoke everywhere. I thought of getting the PWR radiator but I am instead going with Motorsport's radiator ($195).
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
The PWR radiator has a multipass cooling tube in it and the stock one only passes through once. The other advantage has already been mentioned - no plastic. You have a couple of choices for a replacement, but there is a reason that the PWR is sold for more - the construction. Some of the members who have installed them have mentioned that the car runs cooler in the summer.
Brian |
Used to have: 1994 Pearlie, 40,945 miles, PWR Radiator, Motorsports Aluminum Crank Pulley, Raceconcepts Stainless Brake Lines, Axxis Ceramic Brake Pads, ATE Super Blue Racing Brake Fluid, Dimpled/Slotted Rotors, BBS STi 17 Silver Wheels, Toyo Proxe4 225/45/17 tires, New Dekka Battery, Unauthordox Racing Oil Cap -- adds 3.14 hp, OEM Coin Holder FFTDS aka Force Field Theft Deterent System. Magnetic oil drain plug, Purolator larger oil filter. Now she's in good caring hands at Earls place. |
The SVX cooling system is pretty stout stock. Yes, the radiators spontaneously split open, but an OEM replacement one seems to work just fine.
IMO, unless you're racing the car... you just won't need the bad assness that is the PWR rad.
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
once you start asking questions like these then you have to start asking whats the point of even buying an svx? cause it simply rocks out just like the pwr rad
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
