Wynndi got me thinking about transmissions
He got great mileage out of his 1996 which, as we know, had all of the Subaru upgrades. The fact that beefier components helped is not a surprise. And I can rationalize why they may not have put better components in the earlier trannies. Cost. They may have, incorrectly, assumed that the components they had were good enough and when cost pressure mounts, you don't put more expensive components in unless you absolutely have to.
One technique people have used to improve reliability in the older trannies was to open up the passages in the valve body. So my question is, why wouldn't the Subaru engineers have made these passages larger in the first place? It doesn't cost more to make holes bigger. Is there any reason why they wouldn't have wanted these passages to be larger? The thing that got me to this question was that my 1996 with 89K on it seems to be running quite well. There has been talk recently on what the right type of external cooler is. I noticed on my drive to work today that my TC took about 5-7 minutes to lock up. The temperature outside was 35F and I am running just through the stock cooler in the radiator right now. Most of that time was on "city" roads. Seems to me that my tranny is running quite cool with the stock cooler. Given that, I would think increasing fluid flow would be more important than improving cooling, assuming that the tranny is in good condition. That has been my assumption all along and it was reinforced today. So an external cooler with lower flow resistance would seem to be a much better choice than a high capacity cooler. In fact, a high capacity cooler may be a negative as it will keep the TC from locking up and degrade fuel efficiency. Therfore, a low capacity cooler with low flow resistance would seem to be the way to go and that points to a small tube and fin cooler. Once you get past that decision, one then naturally wonders what else would improve flow and line pressure and that brought me back to those valve body modifications. It makes sense with the exception that one has to ask why the Subaru engineers didn't just make the passages larger in the first place. It makes me wonder if there wasn't a logical reason for wanting them smaller.
Re: Wynndi got me thinking about transmissions
Regarding the valve body holes, my feeling is that they were unprepared for how theory and reality seldom mesh as one expects. It's possible that on paper the valve body had sufficient flow, but in reality that flow is restricted by debris build up or some other interference. Maybe Subaru rushed the 4EAT into production too quickly and short-cut the durability testing.
I don't drive my SVX in the winter anymore, but it always took a good while to warm up to the point of T/C lock, to the point that I didn't like getting on the highway too soon and winding it up to 3000 RPM to keep up with traffic. With an external cooler I think you'd want to have a block-off plate for winter driving. Actually, now that I think about it, I've driven my car on days so cold that the transmission would unlock every 10-15 minutes on the highway to re-heat itself. Obviously in cold weather the 4EAT doesn't have heat issues. I think the ultimate solution would be to have a thermostat controlled external cooler. I would like to see the trans fluid running through a warming circuit during the initial part of driving to get quicker lock up and better mileage, then switching to a cooling circuit as required to maintain the minimum lock up temperature.
I don't have much experience with the SVX, but in general, I know that when a company designs a car much more ambitious than their past models, chances are that they don't make a good car...I mean how can you know that your tranny will overheat unless you try it...some things can't be calculated
I don't know but maybe they were in a hurry in some sort and didn't have enough time to test the parts out Reminds me of what McLaren did with their Mp4-12c...They designed the car, gave it to the press, and fixed the issues for a year or so...now they sell a car with far less problems than it might have had one year ago
DIY FTW! 1993 SVX 25th Anniversary Edition @+142k -Rebuilt Tranny @135k -Regasketed Engine @140k -Enkei Raijin 18x8.5, with 255/35/18's @140k -BC racing Coilovers (From STI's) @142k |
I realize that these transmissions had a number of shortcomings out of the gate, but weren't the vast majority of premature failures due to a screen in the ATF cooler loop becoming blocked by bits of friction material?
dcb |
The earliest failures were from bad torque converter linings which were prone to "wearing" quickly and particles getting clogged in the screen, causing a lack of flow, lack of pressure, therefore causing slipping, causing heat and the process quickly got out of hand causing failures. The very earliest 92's also had low/reverse clutches/drums that were much to small leading to reverse failures.
Most of the holes drilled in the later transmissions were actually in the clutch drums/hubs and not the valve body to allow more fluid to reach the friction discs in the clutch pack. Keeping them lubricated and working better. Also, by the time the 95+ were around, the word was out to watch the transmissions. Fluid/filter changes were kept more aware which also leads to longer transmission life. All in all, there are a huge number of factors and variables. They also had no reason to believe there would be transmission issues. It was the same basic transmission that had already been out for a few years in their other models without a high catastrophic failure rate. They used the existing design but upgraded the amount of clutch packs which in theory should have worked. The same 4eat are used in all other subarus of the 90s that go well into the 200k+ mile range and much higher with transmissions that are technically weaker than the SVX one. Keep that in mind. Last edited by 1986nate; 12-02-2011 at 11:00 AM. |
