HID Relay harness
i was looking into HID installs ( i havnt installed mine yet) and some people have suggested to use HID relay harnesses
any inputs?
Re: HID Relay harness
I have never needed to use a relay kit for the Lava Lux 35 watt set.
The DDM Tuning ones are plug and play; no relays required.
My headlights keep burning out and my HID fogs do not work AT ALL! I tried buying a relay and it did nothing.. I don't know if you'll need it or not for DDM (same as my fogs).
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
If you're using the stock headlight wiring to power your HIDs, they're already on relays.
U took the words right out of my mouth . I have small transformers that attaches to the inside fender well , has a wire that attached to the original plug and that has a wire with a plug that plugs into the HID bulb that goes into the original socket .
my svx had that harness in the spare tire well when i bought it. i will check to see if it's still there because i have no intention of add HIDs. the purpose of the harness and relays is to not run the amount of power that HIDs take through your stock wiring and relays, they were only designed to provide enough for stock lights. since everything on the svx seems over made you would probably be ok without it but i have seen crappier cars (hondas) that it melts the whole harness.
