is this right for svx wheels?
# 17" X 8"
# 5 Lug On 4.5" Bolt Pattern # 45mm Offset I should have asked if they will fit on a SVX Thanks, Keith Last edited by kwren; 10-04-2010 at 01:05 PM. |
Re: is this right for svx wheels?
Umm, doesn't the offset need to be a little higher; +53mm? (I know that's what the STI wheels are)
Ideally yes, you'd want a bit more offset. However, if you go with a slightly narrower tire (225/45/17) you'll probably be fine. The 17x8 +53 BBS's have plenty of room to spare.
