Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Audio/Video/Nav/Security
Old 08-25-2013, 12:23 PM
Huskymaniac's Avatar
Uses the ignore feature
Custom DIN slot cup holder
I just completed my custom cup holder. It is made from Plexiglass. I replaced the double din stereo with a single din Pioneer. I put that in the lower din slot. In the upper din slot I installed a pocket. There are two upper and two lower rubber foam strips on the sides of the plexiglass to hold it firmly in the pocket and provide some stabilization or shock absorption. There are two plastic clips holding a steel rod which swings down to hold straight sided bottles. There is a Neodymium magnet glued to the plexiglass to hold the steel rod out of the way for tapered travel mugs.
Tony
Old 08-25-2013, 02:41 PM
Re: Custom DIN slot cup holder
You MADE THAT!
Very cool!
Can it fit an Asti bottle?
Old 08-25-2013, 03:05 PM
You MADE THAT!
Very cool!
A half-bottle perhaps. Asti is just Moscato. There are some wineries that actually make half-bottles of the stuff. In fact, you can get half bottles of Moscato Ice Wine. REALLY good stuff. I will put a bottle in there and see if it holds it.........
Tony
Old 08-25-2013, 04:58 PM
processengr's Avatar
[QUOTE=svxfiles;727611]
You MADE THAT!
Very cool!
+1!!!!
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-25-2013, 05:42 PM
I have found (and ordered) OT's favorite in both the 375ml and the mini 187ml bottles.
Old 08-25-2013, 07:21 PM
I'd like to see a picture with a bottle or can inside it.
Old 08-25-2013, 09:55 PM
What kind? Unless it is too big for the hole it would look like my pics but with a bottle inside.
Tony
Old 08-26-2013, 06:25 AM
I was curious about how level the can sat, how much of the radio and HVAC controls it blocked.
It seems like an awkward place to put a drink but it looks well done.
Old 08-26-2013, 12:00 PM
steamer99's Avatar
steamer99 steamer99 is offline
Nice work, would it fit if you swapped it and the stereo?
That is the same place that Subaru put them in the 97 & 98 Outbacks that I had, the thing to remember is drink the liquid down a little before placing it in the holder. Both of the Outbacks mentioned had radio buttons that did not work, when I bought them, due to pop or coffee being spilled down the front
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
Old 08-26-2013, 01:39 PM
Same problem with Audis. I need to remove my climate control and clean all of the buttons. :/
Old 08-26-2013, 10:27 PM
If you use a tapered travel mug and flip up the steel rod, spilt coffee will run down the top surface and into the pocket where it is held nicely (assuming we are talking a small spill here) until you can remove the holder and clean up the mess. I don't drink soda. An accident with a water bottle is minor, again, assuming a small spill.
Tony
Old 08-26-2013, 10:57 PM
Green1995SVX's Avatar
It would be pretty cool to put some LEDs mounted to the back side of the plexi and do a notch like thing around the outside to give it a lit border kind of a thing. That's how the cup holder in my Volvo is and it gives it such a neat look at night. One LED generates this entire ring of light because of how the plastic of the cup holder is notched. It works kind of like how the BMW angel eyes work.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-27-2013, 12:00 PM
That would be easy to do but I polished the edges of my holder so they won't scatter much light.
Tony
Old 08-27-2013, 01:08 PM
Here you go. With no can/mug and the rod on the magnet the display and controls are all visible and accessible. With a can/mug, the display is blocked but the controls are still visible and accessible.
Tony
Old 08-27-2013, 06:42 PM
Not bad Husky. Does it slide in when not in use?
