Old 09-11-2011, 01:53 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Grille Light Modification.
I never minded the Lancer's but they are in an entirely different class than the SVX. The SVX stands out more than a Lancer by far because of the unique styling. I'd drive a Lancer if someone gave me one and I'd probably love it... Just not more than my SVX..
Now a 3000GT... That'd be fun.
Old 09-11-2011, 02:12 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Originally Posted by fun173 View Post
You think Scions are douchy? You have got to be kidding me. The only way a Scion could be douchy is if it is 1 of 2200 and BRIGHT Yellow, that would make it douchy.
Thanks for the comment SVX1999
Yes, they are quite douchy. I mean, the come "Pre-riced out" straight from the factory without any real performance mods in them (just looks) but the owners still seem to think they are driving a million dollar super-car.
If you like them, go for it :P ....as for me
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 02-27-2013, 10:56 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
I agree with John. It is your car and if you like that, great. It is very interesting to me. I don't know that I will do it or not, but it is cool just the same. I got your email and will get the How-Tos posted tomorrow.
Did you ever get around to posting the How-Tos? I was looking for the one that shows how to remove the center grille?
Thanks
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 03-04-2013, 06:03 PM
fun173's Avatar
fun173 fun173 is offline
#1 BRODAWG!
Thanks
IIRC, there are 4 clips on the back of the grille that you have to loosen. You push in the tabs on the clips, and the grille will slowly come out. I don't believe the DIY included how to remove the grille.
Old 03-04-2013, 10:01 PM
There are TWO clips (one on each side)
Just keep a little outward pressure on the grille, while sticking a small screwdriver down into the top clasps.
once the two top clasps are loose, tilt the top out while pulling up (as the bottoms just slide down into a grommet) and it should pop right out. Installation is just the reverse.
Done this many times.
Old 03-05-2013, 11:14 PM
fun173's Avatar
#1 BRODAWG!
Yes, I meant to say two clips, not four
Old 03-05-2013, 11:45 PM
The 97s have 4.
Old 03-05-2013, 11:54 PM
fun173's Avatar
#1 BRODAWG!
I had both grilles, never did care for the 97 grille. I believe I still have the modified waterfall from the first post in my garage somewhere. I should really put it in my room.
Old 03-06-2013, 01:51 PM
fzftw's Avatar
fzftw fzftw is offline
Just dip a toe!
Originally Posted by Landshark View Post
i love this thread.
Me too. Good fun here.
-Brian
Current fleet:
89 D21 2wd
91 XT6
93 D21 4wd
95 SVX LSi
02 Windstar Sport
03 CL500
03 Avalanche NF
07 RDX
08 Outback
10 Outback
10 Murano
12 Accent
15 STi
Old 10-01-2013, 07:53 AM
Pav625's Avatar
Pav625 Pav625 is offline
... a work in progress
Any "How To's" on opening a waterfall grille? Haven't decided on a light, or as someone mentioned in another thread, putting an external EZ-Pass transponder inside one. Got it out of the car, but curious if there's an easy way to open it up without damaging it
1992 Pearl LS-L : Trans-cooler / ecuTUNE Stage 1 Chip / Pioneer AVIC-U310BT Navigation
I hear what you're sayin', but whatta ya mean?!
Old 11-24-2013, 09:56 PM
simboglide's Avatar
simboglide simboglide is offline
Instructions are pretty damn vague where to put the screwdriver. Looked to me like they're pinch clips.(?) squeeze them and pull the grill forward. I literally blew a bulb and need to remove the headlamp to get the glass out.
.[/QUOTE]
