Trans cooler mounting location
I'm installing my new (to me) aluminum radiator (thanks Bobby and Old Tom!), but it doesn't have an internal trans cooler. I have a separate trans cooler but I'm trying to decide where to mount it.
The best spot seems to be right behind the grill, but in order for it to fit, I have it turned sideways. Does anyone know of a reason to not do it this way? The only issue I see is that the license plate blocks half of it. Thanks for any input.
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
Re: Trans cooler mounting location
Wouldn't it make more sense to put it on the other side? (mirrored to where it is basically). Since the stock trans cooler lines come out on that side.
But, yea, as long as it's not too fat to fit between the rad and condenser, that should work fine.
I was gonna put it on that side, except that the bracket for the temp sensor is in the way. I'm going to need to extend the trans hoses anyway.
It is too fat to fit between the condenser and radiator, so that's why I'm putting it all the way to the front. On another note, I noticed that the power steering cooler was bypassed by the PO since it was rusted through. Do you think that's a problem? I'm using Wolf's Head synthetic ATF, so I hope I'll be ok without it.
you can install the trans cooler in the driver fender well pretty easily, i think there is a write up about it. that's where i put my auxiliary cooler that looks to be about the same size as the one you have, and it would be easier to get to if you ever have to mess with it. power steering cooler isn't that needed unless you drive it hard through a lot of turns, but is very easy to add on if you want.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
I think I'll keep it where it is in the picture. That way it'll get some air pulled through it by the fans when the car is stationary, and besides I already made brackets to mount it there.
I'm not worried about the power steering cooler much, but I may look at the one from my parts car to see if it'll hold fluid. I have everything apart anyway and I like having my car how it's supposed to be.
no cruise...
Ok, so now I think my tranny is too cool.
Not awesome cool, but not getting warm enough. I took it on a 4 hour trip (2 each way) and cruise control wouldn't work. The button light comes on, but when I try to set the speed nothing happens. As far as I could tell the torque converter is locking up. Driving at exactly 60 mph my tach reads exactly 2000 rpm. The speed limit was 55 most of the time, so I would think that cruise control would work normally after driving a few minutes at that speed. Anyone have any ideas? P.S. at the end of the trip I felt the cooler and hoses and they didn't feel much warmer than the outside air...
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 Last edited by SVX8588; 04-04-2012 at 07:37 PM. |
