Antenna
I just replaced my head unit, and was wondering how hard it is to change out the powered antenna for a non-powered one. there is not a switch built into my new stereo, so it can't put the existing antenna up and down.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit. Next changes ... PAINT, fix engine problems, 4.44. (GONE) '97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE) |
My silver had a non-powered aftermarket antenna when I bought it. There was only a single retaining nut holding it in, and I'd think installing a new one would be very simple.
dcb |
dump the crappy head unit.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
I love the new head unit. I hardly listen to the radio anyway.
I was mainly wondering how the powered antenna is wired in and how the non-powered ones are wired in. I need to know if i need to take out the power moter to put in the non-powered antenna.
The power antenna assembly was still in place on mine. The new mast attached with a butterfly-anchor sort of deal with a single nut tightened from the outside, and the lead from the antenna was plugged right into the stock lead.
dcb |
Why dump a perfectly good antenna? You might want it if you ever install a new HU (or re-install the stock deck).
It's also nice to retract the antenna when you go through a car wash! I'd add a switch behind the center console near the back, connected to +12V accessory. Turn it on during those rare times that you need to hear the radio.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses Last edited by SVXdc; 12-23-2006 at 02:32 PM. |
Check the wiring diagram - the antenna only needs one wire and ALL new headunits should be able to control it - there (shouldn't) be anything special about that it... that i know of. There again the mast on mine is broken (stupid kids) so I haven't been able to try it out. |
For removal and installation instructions, see the How-to document
http://www.subaru-svx.net/photos/files/How-To/28253.pdf ,
