Strut removal questions + pictures
I've taken a few pictures and getting ready to replace all 4 of my struts this weekend.
A few questions I need clarity on: 1) Which flange bolt do I "mark" for the camber. Are they both bolts and I'm not sure how I'm marking them. 2) Do I need to mark any bolts on the top where the strut mount bolts to the car? 3) How do I tell which rear strut is the left and which is the right? I don't think I see a part number? 4) In the picture (koni's) installed...do I need the "white" washer on the shaft of the strut? I'm not sure what it is, but it came to me that way. Also is there anything else in particular I should be aware of such as critical alignments or things of that nature? (I'm attempting this myself) Last edited by msvx95; 05-06-2011 at 07:33 PM. Reason: Added pictures |
Re: Strut removal questions
if you look really close you will see that the top bolt has a little mark on the strut for indexing directly vertical and the bolt has little lines on the flat part, you may have to clean them off to see it well. mark the bolt where it aligns with the notch on the strut. that's the one to mark. you don't have to mark where the top mount goes into the car as it doesn't really move enough to make very much difference. you can tell which is left and which is right by what side the brake line bracket is on. as for the konis i don't have them but that washer looks like it is just for shipping. i would recommend getting the car aligned when you are done to keep your tires from wearing odd, even if it drives straight it could ruin your tires.
I don't think that white thingy is just for shipping. I d koni strut insert installation for some general info about the process (because info specific to the SVX, as usual, is scarce) and I remember something about it being needed. I also vaguely remember reading something about needing bump-stops, but I'm not sure where to get them.
Edit: Maybe here? http://www.ground-control-store.com/...tion.php/II=10
Ok I can look to see which side the bracket goes on...basically I can remove the ones on the car and note the position they are in for determining left and right.
Well I bought new bolts, so marking the old ones negates the alignment right? I can check the current strut and bolt to see if there is an alignment mark anyways. Yes I plan on driving it 2 miles down the street for a 4 wheel alignment when I'm finished. I want to say the white thingies are for stopping any debris even with the boot on top of it....I could be wrong. |
I don't think I have ground control do I? I got a set of struts with the konis in them already. It comes with an adjustment knob but no foam stop.
Do all Konis have ground control? Or is this an option when ordering? Perhaps I'm not familiar with the terminology. |
You do not have to have the ground control springs to use the ground control bump stops. If the factory ones have bump stops, then you can just re-use those and if not then I guess you don't really need them. Up to you. You should also re-use the stock dust guards.
