question about DIY u-joint replacement.
i think my u-joint is bad, i can see grease leaking out and i'm getting the front end shakes. i couldn't see when i was under there but if i remember correctly there is a u-joint in the rear too, is it the same size(part #) as the one up front?
You will need a shop press in order top replace them
Tom |
The part that you are trying to describe, does the shaft go to the wheels, or from front to back?
oh, sorry, it's the main drive shaft(front to back ). i would like to just have it rebuilt but time and money are factors. i do have a shop press do you think 20 ton should be sufice? i'm just not sure which parts should be replaced, i know the front is bad, but beyond that i can't find anythreads that have specific parts or #'s for other parts that i should fix while i got it out.
