Old 12-16-2007, 10:43 PM
cruisen_15's Avatar
cruisen_15 cruisen_15 is offline
air compressor
does an air compressor posses enough air to give me any psi?? could i use it like a shot of nos...??
Old 12-17-2007, 06:55 AM
Speedklix's Avatar
Locker Link Solution
Fixed it
Originally Posted by cruisen_15 View Post
couldn't i just use a shot of nos...??
You would need to shoot it out of a scuba tank directly into the mixing tunnel with software to manage the timing and fuel... that said you will not see too much improvement.... just use no2 to achieve REAL results with FAR less effort.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 12-17-2007, 06:47 PM
A compressor? Like the $10 kind you use to fill your tire when it's low? Not a chance. If, as Speedklix suggested, you used a SCUBA tank to fire a massive rapid blast of air into the intake, I'm betting the car would just stall. The software wouldn't be able to adapt quickly enough and you would run hugely lean, and stall.
Old 12-17-2007, 11:05 PM
Hondasucks's Avatar
Subaru Technician
Either that, or all the air would blow back out the intake.. The compressed air is going to find the path of least resistance, since you'd be dumping it into the intake somewhere, it'd just shoot right out the air filter box...
1986 VW Jetta
Old 12-18-2007, 05:18 AM
Speedklix's Avatar
Which is why it would have to be placed way in there to see any benefit.
-Mike
[SIGPIC][/SIGPIC]
