Little torque problem.
I have swap the car over to manual and after i just have stock clutch i have wait a little whit the Torque control on the ecu. But now i have take a jumper wire and i think i have done it rigth.
And i take the car out for a test drive. And its feel verry good. But some times this happen i press the pedal down and the car just hold the same speed in 2-5sec and its feel like a turbo start to go then its set speed. (Its only have happen i 1 and 2 gear) What can this bee? i have a little exhaust leak can it bee this or are can it bee the jump wire its not coneckt right?
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
Re: Little torque problem.
Some one have anny idea of what this can bee?
Maybe your throttle position sensor, the how-to for testing this is in the how-to's
Do you have a cable clutch, if so loosen the cable. (Not as tight.)
Yes i have Cable clutch. The clutch are not ''spin'' (i dont know the world for these) But i can also check the waier on the car.
But this can not bee the torque jumper, on the ecu??
I should look at this also.
