Old 12-18-2014, 10:03 AM
Lifting a car
Looking at getting a car lift. It is a portable unit. Capacity is 3,500 lb
My car is a 5 speed and has a fiberglass hood.
Spec say stock weight is 3,580. Fig for loss of auto tranny and hood.
Thinking my car is under 3,500 I am sure the lift is good for a few lb over.
See QuickJack car lift to see what I am talking about.
Opinions welcomed.
Old 12-18-2014, 10:25 AM
Blacky Blacky is online now
Re: Lifting a car
3580 lb is that full of fluids? Oil, coolant, gas, brake fluid, tranny fluid, it adds up quick. See if you can get it weighed at a local gravel pick or such.
In my opinion you're pushing the envelope. I know the max. weight of the lift is conservative but...
For a difference in price of $260.00 get the BL-5000.
Old 12-18-2014, 10:26 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: Lifting a car
Play it safe and shell out the extra dough for the BL-5000.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 12-18-2014, 10:28 AM
Re: Lifting a car
Opinions welcomed.
Personally I wouldn't want something that is so close to it's maximum capacity.
Old 12-18-2014, 11:04 AM
Re: Lifting a car
At my old shop we installed a Snap-On hoist and I asked the tech what the factor of safety was. He told me that every piece of equipment is tested to double the rated weight before leaving the factory. That's Snap-On though, not sure if I would apply that same confidence to other manufacturers.
3500 lbs is pretty light though. I would look at something with a little more grunt both for peace of mind and in the event a friend owns something a little porkier and needs the tires swapped over.
Old 12-18-2014, 01:27 PM
Re: Lifting a car
A vintage car collector near me uses the EZ Car lift system. Mainly collects 50's vehicles. He currently had a 1956 caddy on the lift, which he said is about 4400 lbs.
He loves this system and has never had an issue. Really solid. He said he would let me know when the lift is free so that we could try the SVX on it. He has seen my car and says this would be no problem. I have seen it standing in his garage and watched him put in under his vehicles.
Website:www.ezcarlift.com
Re: Lifting a car
My 2 door Honda Accord is 3,200. I am thinking the $250 would be well spent. Unless my wife ordered it for me for Xmas.
Old 12-18-2014, 01:41 PM
Re: Lifting a car
when i had my first lift installed the installer said i could use it past it's rating but it would shorten the life of the lift. it's a 10k lift and he said he knew of people lifting up to 15k, the only difference between the two lifts was a larger hydraulic motor and heavier cables. the electrician said that if you exceed the capacity of the lift it will blow a breaker before the lift breaks.
i have never exceeded the weight limit just passing on the info i have heard.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1956 Plymouth Belvedere - Daisy
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 12-18-2014, 02:16 PM
Re: Lifting a car
If she ordered it I will use it. The company said it will lift 3,500 with ease. Since my car is not stock I can easily drop it below 3,500 just by doing it with a 1/4 tank of gas ( -80 lbs ) remove the spare ( - 25 lbs ) and with the all ready 75 lb reduction or more should be good. Hopefully she just gives me the money.then I January add to it and order it myself. Who said friends could use it?
The EZ lift has rollers and can only be used on a smooth surface. One end is stationary the other rolls. Also it has 2 cross bars making under car repairs more difficult . My garage is not wide enough I have to do it in the shelter or In the driveway.http://www.garageautoequipment.com/Q...-p/bl-3500.htm
Old 12-18-2014, 02:21 PM
EdWindows's Avatar
Re: Lifting a car
He loves this system and has never had an issue. Really solid. He said he would let me know when the lift is free so that we could try the SVX on it. He has seen my car and says this would be no problem. I have seen it standing in his garage ans watched him put in under his vehicles.
Seems like a great product, only 2 problems I see with it:
1) It costs $2000!! You can buy a real hydraulic floor post lift for that price!
2) The design looks like it would impede a transmission, driveshaft, or gas tank removal on most cars.
Old 12-18-2014, 03:53 PM
Re: Lifting a car
My friend has a large aluminum garage that accommodates 6 cars at a time. What he likes about this system is that he can lift the car, work on what he wants and, using the optional casters, push it abound the garage. Can move it out of the way to bring in another car and work on something else and come back to it.
He never mentioned any limitations on the crossbars. I have seen him do exhaust system work without interference.
Old 12-21-2014, 12:22 PM
Re: Lifting a car
Just ordered the BL 5000 quick Jack. Got it free shipping and only $150 more than the 3,500 lb. No Brainer. Had to have it shipped to my buddies warehouse to save delivery charges. Pictures to follow.
Old 12-21-2014, 01:45 PM
Re: Lifting a car
Good choice!
Old 12-21-2014, 03:10 PM
Re: Lifting a car
Got this one. Should have it mid Jan if not sooner
http://www.bendpak.com/Shop-Equipmen.../BL-5000.aspx:)
Got an e mail today. They may ship on the 5th. Xmas screwing up the works they test it before they ship. QC not working next 4 days.
Old 01-13-2015, 05:40 PM
Re: Lifting a car
Lift came in today. Looks real beefy. Will not fit in the rear of the SVX with rear seat down. About 4" to long. Without a passenger I think I can squeeze it in. Weight is just about as much as u can safely carry. 40/45lb each side is my guess.
Still in the box. Only10 deg. Waiting a bit to instal fittings and hoses.
