Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 04-28-2010, 11:35 PM
Banned
Momo steering wheel with airbags that work???
I did some searching because I saw a lot of members that had momo's that they didn't have the airbags functioning on them.
I found this on ebay and was wondering if, since it's the same generation if the plugs would be the same and I could get the airbags to work???
http://cgi.ebay.com/ebaymotors/JDM-S...ht_4051wt_1165
any thoughts???
Old 04-29-2010, 09:39 PM
Re: Momo steering wheel with airbags that work???
Its not a matter of just the plugs being the same, but also the voltage that is sent to the airbag unit to deploy it as well as the constant signal that tells the airbag computer that everything is in proper order.
Even then, you still end up with an airbag that was designed for a different car with different dimensions.
Old 04-30-2010, 03:08 AM
I might have an idea Johny. PM me...
Old 04-30-2010, 02:54 PM
NeedForSpeed NeedForSpeed is offline
PM me, I want to know too
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 04-30-2010, 03:19 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Just post it! We all want to know!
Old 04-30-2010, 09:33 PM
I've got an idea, but I don't know if it would work or not. Just get an airbag control unit from the same car. If the sensors are different then get those too. As long as the overall layout is the same with regard to sensor positions, then the only issue would be in whether the airbag controllers communicate with anything in a way that would cause problems.
Old 04-30-2010, 10:55 PM
Green1995SVX's Avatar
That will not work. I have ordered several momo wheels from Japan and tried them. None use the same plug orientation.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-30-2010, 10:59 PM
sabin sabin is offline
Banned
my svx is airbag free
Old 04-30-2010, 11:32 PM
Also, switching over the entire air bag computers, sensors, wiring, etc out of another car will probably not work either. The air bag computer recieves input reguarding the speed of the vehicle so that they never deploy below certain speeds.
Old 05-01-2010, 05:15 AM
If the speed is sent to it as a pulse, couldn't that be accounted for? If it's data, then that might be a problem. Also, if the two cars require different speed thresholds.
Old 05-01-2010, 05:27 AM
Also, that makes me wonder. A few weeks ago, my speed sensor (the one that is reported to the speedometer) broke and I replaced it quickly. In the meantime, having no speed, would the airbag have worked at all? I think the problem could probably be solved with enough electronics expertise. And maybe someone could even reprogram the airbag controller to make it work just right.
Old 05-01-2010, 09:31 AM
Possible, and like I said, I don't know for sure if it gets the signal from the ECU or not but it somehow has to have a signal for speed.
Not saying its not possible, just that its not going to be as simple as what most people would automatically think, that's all.
Also, I personally wouldn't be f*****g around with different airbags.... Don't need a "bomb" going off improperly.
Old 05-01-2010, 10:04 AM
Freeman's Avatar
Unregistered User
Yeah I totally agree. That was my first thought the second I saw this thread.
Old 05-01-2010, 01:33 PM
sowise sowise is offline
I know the airbag technology is popular for safety but other than maybe turning of an airbag light I don't really see the point in making a different one work. I know people swear by them and I do concede they improve your chances but there are also downsides to them as well. Wear a seat belt and drive defensively. Plus I would put our SVX up agains a prius anyday.
Old 05-01-2010, 02:39 PM
Yea, but what about a hummer?
