For all new parts, cost is around $1675 + I need your old struts. Spring rates are based on your driving habits. Color is your choice.
awww, shucks Thanks Handling is good but I need to reduce understeer further. I'm going to up rear rate with new springs this winter and then make the larger rear bar. Uping the rear pressure on the tires has had a dramatic impact on rear rotation. 38 psi is my favorite setting with 45psi up front. I can't recall the rear spring length off the top of my head, but I believe it's 8". I'm building the anti-sway bar bending machine frame this weekend I have a Hossfeld bender with all the dies. I can even do roll-cage tubing with it...when I get the hydraulic power-pack for it that is. Nice work and I need to talk to you about the rear mounts. Todd
Down to none |
If either of you guys are still making/selling a bigger rear swaybar lemme know
I'm not ready to offer them to the general public yet. When I do it will be complete with adjustable endlinks and the bar will have three settings.
Todd
Down to none |
Mychailo I checked the rear mounts and the bolts are smaller did I miss understand you?
Hmmm...with the Megan Racing group buy not looking so good I may be getting in touch with you about something just like this over the winter.
My old struts have been subjected to 15 Canadian winters (snow, salt, and nastyness). Would you still want those, or would I be paying the core cost?
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 10-06-2007 at 04:17 PM. |
I mainly need just the bodies. As long as the bodies are too badly rusted, I could take them.
mychailo, you had asked about the 450 front rates on my car... Seems to be a great fit for my car... Handles wonderfully at the auto-x and they don't really push at the limit at all... Now for some sway bar upgrades and I will be all set...
Tom |
Hi Tony, I think there might be a misunderstanding. The rear mounts I'm using on the Koni/GC setups would work well for your driving. Finding fronts that work for your driving would need further research. Seems that a few people are dimpling their hoods with the Koni struts after big potholes, etc, so other people might start researching this too. The SVX front top mount does not have an equilateral triangle bolt geometry (most top mounts are equilateral triangle) making it necessary to drill at least one new hole in the strut tower to use a substitute mount from another car.
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 10-07-2007 at 10:28 AM. |
I now am the proud owner of a dimpled hood. Would love any intelligence about a beefier front top mount.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
My DMS have a spring retainer that won't fit through the mount so my bonnet didn't get damaged.
So is this till going cuz i need to net some new sturts fast and soon.
PM'ed you.
#29
Very, very nice! Eliminates the need to heat treat to bring the strength back up (yes, it's a hassle...). How big a diameter of solid stock will you be able to handle? Got a local supplier of 4130? -Bill
#30
verry nice
wish I was rich those look sexy I'd love a set on my SVX but I'm afraid I am way too poor!
