#31
Re: Cheapest/Easiest Way to get to ~400 crank HP
Ok heres another question. Would Having a EG33 Bored to 3.5L will it still be ok for using for normal road use... Like having the bore walls thinner could they go out of round quicker etc? or End up with engine failure quicker?
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
#32
You don't just bore it out of what is there. To go to 3.5 litres you would replace the liners with different thicker ones, so the liners when bored would be as strong as [or stronger than!] standard. Joe
#33
Jack's engine was bored out to 100 mm with the standard liners. So far it has survived numerous dyno sessions and some parking-lot antics, but it has yet to see track duty this year. His machinist used Jack's spare (junk) block as a test dummy, and they drilled some holes through the stock sleeves into the water jacket. They seemed satisfied with the wall thickness for a N/A application. I can't comment since I don't know the actual wall thickness myself. |
#34
1992 LSL Pearlie: 108k, 15min/$15 mod, Alternator wiring "upgrade," Power Mode switch, K&N drop-in, 4500k 35w low-beam HIDs, 3000k 35w fog HIDs, lots more planned (pending funds, of course)- 4.44 5spd being at the top of the list. "We laugh at honour and are shocked to find traitors in our midst." -C.S. Lewis |
#35
He measured the factory sleeve wall thickness at about 0.160", and as I remember we thought that we could bore the cylinder out to 100mm to match popular pistons, and available head gaskets. The aluminum casting surounding the sleeve is about 0.250" thick. He thought that that was a safe overbore if it was not supecharged, or turbocharged, but untill someone does it this is all just speculation. Tom
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 02-18-2009 at 05:38 AM. |
#36
I was talking to Ron last year. He was planning to bore and stroke one of his engines to 3.7 I think. He likes the idea of a more powerful NA engine.
I'm not sure what dimensions he was going on the bore, or whether he was re-sleeving. My own gut feeling [speculation, for sure ] is that with the cost of work involved in boring out it is not worth the risk to run with thinner standard liners in relation to the cost of replacements. Absolutely not for a blown engine. Others may see it differently. For a road NA engine that was not going to get grief it might be OK I expect. I personally would worry about head gasket integrity and would opt for belt and braces. I'm tight with money. Joe
#37
If this in fact the case, I'm going to go out on a limb and say it's plenty safe for an N/A engine then. At 100 mm, we're looking at a 3.1 mm bore increase, or 1.55 mm per wall (.061"). Leaving .100" of sleeve roughly, with a surrounding .250" of aluminum to support it. Heck, I've bored cast iron blocks down to .120" thick walls with no outer supporting walls, and raced them hard. I would still put in sleeves for forced induction or nitrous at that bore diameter.
#38
sorry to bring back an old topic but I was doing some reading I didn't do in feb lol and have some questions.. well one big one.
with all things considered, if forced induction is the end goal would it be advised to bore or not? and if so how much?? |
#39
These 7k numbers seem pretty low to me. You'd need to acid wash the block, port the heads, custom cam profiles, complete intake and exhaust, injectors, valve springs, hydra engine management, pistons and rods, crankshaft balanced, you're at 7k right there, at least. Then you can add your super/turbo charger, at another 5k-8k. 400hp is pretty high, last I heard tom wasn't there, and he has over 20k in his engine. Then if i recall correctly, you have to have a 6 speed transmission out of an STI to handle the power, as well as sti axels, add another 8-10k. You can make 400hp all day long, but if you toss your trans or snap an axel every time you hit the gas, it's kind of useless.
Not to try to deter you, but setting aside 7-8k, getting less than half done, is very discouraging. I would take it one step at a time, work it, work it, have end game goals, and do it over time. I'm hoping you have another vehicle to drive before dropping 20k into your SVX. Also, be aware that once you do this, you cannot sell, ever.
#40
I make 400 crank all day, the supercharger is for sale and the cheapest way you are going to do it... Just sayin, the option has been on the table for over a year and no one bought it...
Tom |
#41
#42
Generally speaking, if you sell a modded car it will bring you no more money than a non-modded car.
Having been in the "car business" since before you were born, I hate to tell people that the Corvette motor that they installed makes their Camaro worth LESS money than if it had a stock motor... Unless you sell it to someone who REALLY likes it. I would, and have paid more for a Hot Rodded car than a stock one, but then again, I'm not normal.
#43
why the hell is it so hard for the EG33 to hit 400HP when an STi engine has been hitting 500 for abuot the same cost? Are the designs in the 2 boxer engines really that different?
#44
one reason... aftermarket support due to the number of engines out there!!!!
#45
Because it is not an Sti... I would start there Tom |
