Exhaust system
Can anyone suggest a new system (moderate cost) and a installer in the area of Baltimore / Columbia Md. My 92 seems to have sprung a leak somewhere under the driver compartment. Thanks for the info.
Fred |
Hi
Hi , i'm doing same thing here in a month or so. My cost is 600$ all installed .
Doing real seperated exaust starting at the rear of the first cats. no more than 2'' to keep scavenge effect. all way dual exaust to two mufflers ( mine are Turbos from Flow master ) . DO NOT LINK THEM!! since we got a H-6 , they fire evenly every 240 degrees of crankshaft travel.there'S no overlap.this eliminates the problem of one cylinder exhausting while another cylinder's exhaust valve is still open.( taken fromSubaru svx faqs.... )
Nightmare is the name of the car... |
It will sound great above 3000 rpm, and like crap below 3000. Expect to install two mufflers per side to make it sound ok.
Humm....depends on the $$$ you want to put i think..
and i'll fix an other thing, : it's 240 degrees of crank travel...
The REGULAR SVX has a six (6) cylinder, four (4) stroke engine in it.
That means the engine crankshaft has to rotate twice (that means two (2) times) for each power/exhaust stroke. Since a rotation is 360 degrees, and it requires two rotations, that means it will rotate 720 degrees for each cylinder to fire. Since all six (6) fire every 720 degrees, you divide 720 by six (6) and have a cylinder firing, and exhausting, every 120 degrees. Now if you are referring to our engines acting as two (2) separate three (3)cylinder engines, perhaps you should be more clear. The money you spend on a thing is not as important as a proper design. I was only trying to give proven advice. Good luck.
humm
So , the SVX FAQS is wrong? man... I thought it was my bible...
I have the highest respect for Terry McLane and his FAQ.
But as time marches on more people experiment, invent, goof up, and try again. I am on my twelth exhaust system on my Claret, and I am happy with it. Mychailo has had numerous exhausts on his. And we both look to Harvey for answers, theory, and advice.
Harry....yeah
yeah, I've read a lot of post with Harry arguing with others... a lot of fun to read and know that he masters what he's talking about, so to make it short , What is the best thing to do with our exhaust ? Like a How-to thing with the brand and all ? thx
