Final drive ratios ?
What i want to know - forgive me for not knowing much about mechanical being an electronic geek!!
The numbers 4.11 / 4.44 etc does it mean higher number = less reves to get to same speed? or something else. Has someone done the maths to let others know ratios Vs top speeds Vs gear change revs etc? thanks Stephen (1 OF 1 - in NZ) |
Re: Final drive ratios ?
Higher final drive numbers mean MORE revs to to get to the same speed.
On a manual transmission car,( if it had direct 1 to 1 drive) when the car is in gear, the engine turns either 3.90, or 4.11, or 4.44 times for every time the axle turns. Fifth gear is an overdrive. As is sixth. The more times the engine turns in relationship to the axle, the more torque you have.Top speed on a 4.44 equipped car at 7000 RPM, with 24.86" tall tires is about 157.83 MPH.On a car with 3.90s it would be about 170.18 MPH, if it had enough HP.This link might help. http://www.subaru-svx.net/forum/showthread.php?t=46042
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 09-07-2008 at 08:04 AM. |
Thanks very much for the link - all is now clear..
