Alternatives for 4EAT (4.44)
Well, 1996 or not, my tranny is shot. So much for the supposed tech bulletin improvements made from the 95+ tranny versions. I found this thread to help me chose potential alternatives to the ever flawed SVX 4EAT. I had my mind set on a 4.44 transmission/rear diff combo... seems like a cheap alternative. There's a guy on Ebay who sells them for relatively cheap (granted that you might be able to find some cheaper locally if you spend a little time and effort). He states in the swap procedure:
The transmission is almost a direct swap. All you have to do is swap the front speed sensors, the rear lower mounts, and the exhaust hangers around from your SVX tranny to your 4.44 tranny. The rear differential requires that the LSD carrier and bearing plates from your SVX rear diff be swapped into the 4.44 rear diff. This requires some modification to the rear differential housing with a grinder to make room for the LSD carrier, but is easily achieved by a reputable mechanic. First off I'd like to know if it makes sense (not so sure what he means by grinding the housing to make room for the SVX diff parts to swap in the Legacy rear diff if you want to retain the 4.44 ratio compatibility). I'd also like to know if others here have done it an like or regret it. And also since that thread is a year old, there might be some other potent conversions now available that are not listed. Thanks all for your help. I'll try to keep this ebony 96 alive. |
Re: Alternatives for 4EAT (4.44)
Hi,
My daughters 92 was converted to 444 by YT when they had AWD Inc. I would caution you to not obtain the transmission yourself, but to let the shop installing it find the transmission, preferably from a reputable local house to save shipping costs. In the (likely) event there is a problem with the used unit, they will have an ea$ier time rectifying it having sourced it. The newest unit will be at least 14 years old... After the conversion your speedometer will read high by 6 mph. Under light throttle, 2nd gear shift will be abrupt, 2-3 and 3-4 soft. The car will accelerate as if it were lighter. There are quite a few parts that should be replaced as PM during the swap, hopefully one of the experts will chime in.
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
I think the guy selling the transmissions is BudFreak from svxworldforums (SVX Parts Central). Seems he's done this on quite a few SVXs and done a few writeups. I feel I can trust his judgment. So the speed reads 6 miles fast? Well that sucks... is there a fix?
inb4budfreakbash
http://i840.photobucket.com/albums/z...93705d9zzz.png |
Right...
What? |
4.44 comes out of a Forester . Bud is in Ohio . Swap is the best bang for the buck . Usually can be accomplished for under $1,500. Car will feel a lot different, more pep but rev slightly higher at high way speed (+250 RPM)
Anyone bashing budfreak will receive some shiny new points for Christmas.
As processengr said the into second shift is harsh.
(Although I like a firm shift.) Linking to a propper wrightup is not the same as actually writing one. The "How to." is in my signature. Chuckls is showing a way to fix/remedy the mathmaticaly resultant speedometer error by explaining, in picture form, a 4.44 SVX with a 5.5% taller set of tires. (Speedometers should read about 5.5% high unless you install taller tires.) NOTE; This is for 4.44s only!!!!!!!!! Nate is correct about the Forester, LEGACY Outback, LEGACY GT, Impreza 2.5 RS, and perhaps the LEGACY LSI. When I source a 4.44, I get it from wrecking yards that I know and trust. A licenced business is required to be forthcoming in their description of a product. Others can say what they want.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 12-10-2011 at 07:47 AM. |
Would an ATX from an Impreza 2.5RS 2000 work? (transmission code TZ1A2ZJEAA)
PS: I'm asking because the part number isn't one that would match the criteria stated in the thread I refer to, but svxfiles's reply suggests that 2.5RS trannies might work). Last edited by TurboIQ; 12-12-2011 at 11:47 AM. |
