Old 04-22-2010, 02:42 PM
thickasxthieves thickasxthieves is offline
Send a message via AIM to thickasxthieves
Pitch Brace Question
So i stumbled upon a post the other day that said this pitch brace http://www.groupa.ca/PR_pitchmounts.html would fit on the svx along with many early model legacies. Ive also notcied legacy guys using ones for sti's http://www.rallysportdirect.com/shop...unt-p-250.html or http://www.rallysportdirect.com/shop...7143c9bf80410b and basically im curious if sti ones would fit the svx, seeing as as far as i can tell the group A one listed first is no longer available? im really tempted by this mod because its pretty cheap and im always down for putting more power to the ground.
is this mod even worth doing? are the benefits really noticeable or is it marginal improvement at best? im looking for input from anyone that has experience with these.
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver
Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs
parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set
Old 04-22-2010, 07:14 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
Re: Pitch Brace Question
the group N pitch mount is pretty much stock. it doesn't really change anything honestly. almost as if you didn't do anything at all.
the group A one would be more solid ...therefore you'd have NVH.
you probably wouldn't notice a difference at all in power either way
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 04-22-2010, 08:11 PM
I remember reading a post by a member (Mychailo) who had put an aftermarket pitch mount into his car. His comment was something along the lines of "Sounds like the transmission is bolted directly to the firewall. Tons of NVH."
Old 04-22-2010, 08:13 PM
the pitchstop i think is more to reduce drivetrain loss
