Specific lugs needed for SC430 Rims?
I'm picking a set of these up and would like to hear from someone who has had these before or in the know as to what kind of lugs I need to get for this or can I just have the likes of discount tire get me set up and figure it out?
Reason I ask is because I see Dayle from Motorsports mention that it needs different lugs in one of the threads. I'm assuming I also need to get or have centric hub rings installed for these wheels as well, yes?
1994 subaru svx le 112k |
Re: Specific lugs needed for SC430 Rims?
You should just ask Dayle. Not that many other people have used those rims, so you're not likely to get an answer on here anytime soon.
I think that most rims you will need different lug nuts for though. The SVX lug nuts are sorta unusual.
my rims are lexus im not positive of which model they were from but the stock lugs fitted perfectly and i needed centric rings about 2mm thick
Yea, if Dayle notices this and replies, that's fine. He's disabled PMs intentionally not to be bombarded with questions just like this I'm sure so I figured I would just ask openly instead.
Probably not a big deal I just don't want to hassle with someone at a shop telling me it can't be done for whatever reason, just a little prepared for that sort of thing.
Oh, I didn't know that. Smart of him...
I found out the little plastic rings on the wheels are more hype than absolutely necessary. I have them on mine because they came with the wheels . PO told me he forgot to put them on one year and there was no difference . Makes it easier to install the rim
