Old 08-16-2011, 06:29 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
fwd legacy trans
Will a 1995 fwd legacy trans work on an svx, and don't flame me, It's very very temporary.
I has teh FWD LS-L
Old 08-16-2011, 06:53 PM
Re: fwd legacy trans
You would need a FWD TCU, and to remove the driveshaft. Maybe other stuff. Probably not the best option.
Old 08-16-2011, 06:56 PM
92_LSL's Avatar
Can't I just keep the fwd fuse in?
I has teh FWD LS-L
Old 08-16-2011, 09:57 PM
Nope. The TCUs have some important hardware differences, not even just software.
Old 08-17-2011, 05:13 AM
I have run a FWD 4EAT in a AWD 4EAT Legacy, by just installing the FWD fuse, never gave me any trouble, I would think it would be the same in the SVX
Old 08-17-2011, 07:35 AM
Yep, should work fine. I wouldn't see why not. The AWD TCU would be normally looking for signal from VSS1 for different speed, but with the FWD TCU in place, it eliminates it looking for it.
If you end up having troubles with it, I'll bring a FWD TCU just in case.
Old 08-17-2011, 08:48 AM
Tapani Tapani is offline
So this is one of the reasons why a 4.44 AWD tranny controlled by a 3.54 TCU is a bad idea. Inserting the fuse changes the shift points and general feel quite dramatically. Not to mention the transfer clutch binding and jerking in the rear drive. The VSS1 is on the rear output shaft and the VSS2 on the front diff carrier..... the TCU sees quite a slip all the time.
The performance TCU from Micheal with the correct gear ratio programmed in is already at the airport.... will get it tomorrow :-).
Tapani
Finland
