Old 06-28-2008, 10:19 PM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
fuel injectors
Hi all!
I am going out and dropping a dime here (well add alot more then a dime...
What fuel injectors work for the SVX? What cars do they come off of? Just so when I order the parts I have some options....
Thank you all!
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 06-28-2008, 10:23 PM
Re: fuel injectors
Like direct fit, plug-and-play sort of thing, no other mods required? OEM Subaru SVX injectors. If you buy an ECUTune Stage 2 chip you can (actually, you have to) run the Nissan Z32 MAF (300ZX TT) and the 370cc injectors from the SR20DET motor. Someone correct me if I got that wrong, I hate remembering funky engine codes.
Old 06-28-2008, 10:24 PM
Re: fuel injectors
Sounds right, but VG30DETT also works for stage2v7 and comes in packs of six.
Old 06-28-2008, 11:17 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
Thumbs up Re: fuel injectors
correct sir
....sirs
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 06-29-2008, 06:25 AM
immortal_suby's Avatar
Thread Killah
Re: fuel injectors
Are you replacing a bad injector? All of them? Don't run and spend money yet. There are a lot of stock used injectors laying around right now from all the 2v7 people.
Locker Link
2015 BRZ Limited 6MT
Old 06-29-2008, 08:38 AM
Schralper's Avatar
Schralper Schralper is offline
Re: fuel injectors
there's also these options in it's bad injector
http://www.rceng.com/Fuel-Injector-Cleaning-P43C0.aspx
http://www.fuelinjectors.com/
notice on the bottom of RC's page there's math.
based on which it shows 370cc injectors, @ 43psi are good for up to 335 crank hp.
where as stock injectors good for 235 crank hp.
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 06-29-2008, 09:10 AM
Speedklix's Avatar
Re: fuel injectors
I recommend doing this anyway, this is step one for me with all injectors.
I also have at least a full set of SVX red tops, but have not been re-conned as they were the ones I had in last.... but based on your post i assume you're only looking to upgrade; just putting it out there if any needs stockers.
-Mike
[SIGPIC][/SIGPIC]
Old 06-29-2008, 02:14 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Re: fuel injectors
I'll go this way, when I can have it sit for a while.
I don't seem to have any problems, but think it would be a good thing to do while it is not getting any road time.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 07-03-2008, 10:26 AM
Back Road Blazer
Re: fuel injectors
I would proly want to upgrade... However it is going to Subaru today and they are gunna tell me what is wrong with it....
Hopefully it is not too much... lol
-Chris
