Old 04-21-2010, 08:55 PM
Re: Help! Broken Trans Rear Housing(pics)
Originally Posted by redlinedeath View Post
how long do you think that wound take to cure to the point of being driveable? less then swaping the rear housings? the other bolts came out in less than 2 min on the other trans, and looking at my pics, i think these will be quick, but then i have to swap the trans mount, and that sensor, and all that good stuff. i can get some jb from work, and i do also still have the missing chunch in its entirety. any thoughts? i was going to go to my moms at 6 am to do this, but maybe this will work.
If YT's friend cannot help you out I can have a tailshaft housing and new gasket in tomorrows mail!
Old 04-21-2010, 09:01 PM
Originally Posted by TomsSVX View Post
Thank you god.... suggesting otherwise is stupid... sorry, now other way to put it. if you have the parts to fix it right.... why the hell wouldn't you?
I have McGuiverd a lot of things, to get home....
Like the time my brother Mark drove the Vega,
yes Vega,
while I held a case of empty bottles filled with gasoline in my lap, moving the axulirary electric fuel pump intake hose, vice Gripped to the passenger side window frame, from one bottle to the next, so that we could drive it home to replace the failed in tank fuel pump......
But I digress.
Old 04-21-2010, 09:03 PM
redlinedeath redlinedeath is offline
Send a message via AIM to redlinedeath Send a message via Yahoo to redlinedeath
im guessing that gasket is a dealer only part? ive never looked, but i dont think we carry that at work. is gasket maker a mistake? light right stuff, or any of the permatex products? reason i ask is because 20% off when your broke is a pretty good deal, especially when you dont have a car, and need to get to work everyday, lol. i already have the other rear housing from the old trans, and its unbolted, just has to be split(which is proving to be a massive pain, any thoughts on this)
Old 04-21-2010, 09:05 PM
i wish i had the 500 dollars for the 2nd gear replacement on the ra swap so i could swap that in there instead.... damn.
Old 04-21-2010, 09:09 PM
****, if you cannot get the gasket, take a manila folder, trace the gasket and cut it out... It will at least last a year or so till the auto takes a ****.
It is a dealer part, at least I have always gotten them from them. Good thing is, it will work on all 1st gen 4eat's so they should stock it
Old 04-21-2010, 09:12 PM
Part #31337AA120 Like $6-$8.00...
It should not be a major pain...
Try a HD gasket scraper to seperate the two.
PS, Watch the green wire with the brown connector.
Old 04-21-2010, 09:16 PM
My local Subaru dealership
DID NOT STOCK RADIATOR CAPS, THERMOSTATS, OR GASKETS,
untill I finally got through to them.
frick, i even had a manager at work restart the system to check if we carry it, no luck, even looked for a ford ranger and mazda truck, nothing.
ive tried to trace gaskets before... didnt work. at all. it failed a few minutes after startup. so is that a no on the gasket makers? i also have a sealed tube of trans sealer stuff straight from subaru in japan(its all in japanese, idk, my brother said they gave it to him for a trans pan gasket) would that work?
Old 04-21-2010, 09:19 PM
im going to take that part # to work and hope our part# interchange gives us a number for one we carry, cause right now, i dont have a ride to the subaru dealership a town north of me.
Old 04-21-2010, 09:26 PM
YTs home made gasket is at least the right thickness.
I just made one like that, OUT OF GASKET MATERIAL
(part #something/something from Advance Auto Parts)
for a manual transmission last week!
Old 04-21-2010, 09:38 PM
the dark gray one? gasket maker roll of material i mean. i work at advance, and my car happens to be 3 houses behind work at my moms place, so that makes it VERY convenient.
Old 04-21-2010, 09:51 PM
Dark gray, Army green, your trans does not care.
Old 04-21-2010, 09:55 PM
lol, we carry three, cork, one really thin, and one a bit thicker than a manila folder. didnt think it mattered, just making sure!
the fluid completely coated the first half of the driveshaft, and underbody, so i need parts cleaner. ALOT of cleaner. will this eat up the undercoating? i odnt want to have to buy that to.
Old 04-21-2010, 10:19 PM
I have just checked the stock Subaru gasket with a micrometer and it is
0.020" thick.
You are welcome.
Old 04-21-2010, 10:23 PM
dang, you are the man! ill check that when i get there tomorrow! im hoping to get a part number to stock number cross, but ill most likely end up with the gasket material.
thanks!
