Another Window problem
Both front windows worked fine then one day the passengers side won't go down. I checked to make sure the motor was good by by passing the switch with an extra car battery. It went down, then I switched polarity and it went up. I put the Window back down and hooked the swith up again. It went up but not down. With the Window up I push up on the switch and you can hear the motor work. I switched switches from the rear same thing. I did the same test on the passenger rear Window but it work opposite (down but not up)
is it the master switch? Thanks obtw I did do a search and I did make sure that the Window lock button was not activated. Lpl
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
Re: Another Window problem
Bump
anyone?
Try opening up the master window switches and cleaning the contacts. It worked for one of mine that was acting weird. If you take apart the master window switch, hold it upside down while you do, otherwise little springs and stuff will fall out all over the place.
So I hold it upside down? Lol jow dono take it apart?
Thanks for the reply
Yea I found out the hard way too, luckily I was at a desk so the little tiny pieces didn't get away from me and I was able to figure out how to put them back in.
So I took my switch apart.... They contacts seem to be touching right on all 4 bu the Window stl only goes up. New switch?
