guess i was overdue for an atf change . . .
. . . cause the fluid that came out was all burnt and sh*t. Smells horrible. And I only was able to get about 3 quarts out of it. Going to drop the pan on Thursday (the day I get paid) and look around. Also going to buy a tranny cooler if my finances permit. This transmission has less than 20k miles on it, and I've been relatively nice to the car in general since then (i.e. no hot-rodding). What did I do wrong, besides long stretches of highway driving? And does the tranny pan require a new gasket before reinstallation?
TorG0d Francisco Domingo Carlos Andres Sebastian D'Anconia |
Unfortuneatly, no matter how nice you are to the tranny, there is always a chance of particles clogging things up in the tight internal passageways...it's the early design flaw. So even if your tranny fluid is as fresh as a daisy, and exeternal cooler is good insurance to keep it that way. Good luck with the drain, and hope fluid is the only thing you find in the pan when you drop it
Are you having any tranny issues?
-Mike '92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91 "It says here, 'Breakfast any time'... That's right... In that case, I'll have the pancakes in the Age of Enlightenment..." |
yah, automatic trannys are prone to that, you cant beat em like stick.
Not having any transmission issues at the moment, just changing the fluid cause it hadn't been done since I got the new tranny installed.
On a happy note, I'll be getting xenon headlights from work at cost this week. That way, if the tranny does go out at night, I'll have some light for a bit when I have to walk to the next exit. |
yes, you need a gasket - it will probably come with the replacement internal filter.
FYI, if you jack up the passenger side of the car (then use a jackstand), reach under and remove the drain plug, a lot more ATF will come out, reducing the amount that will fall out and make a mess when the pan comes loose. careful tightening the pans bolts, over-torquing tranny and oil pan bolts so the edge of the pan gets warped is a common cause for future leaks. make sure you check & clean the magnet in the bottom of the pan. If there's much of any residue, you should definitely back-flush the OEM cooler (should do this anyway, but many don't). |
Re: guess i was overdue for an atf change . . .
-Chike
If you drain out only SIX quarts, then half of the burnt trans oil is still in there. Whats left behind will contaminate what you put in.
After you drain and refill it drive it for a day or so to thoroughly mix the new oil with the cruddy oil. If you drain and refill twice, you now have, roughly nine clean quarts and three dirty quarts. If you do the drain and refill three times, its now starting to get clean. Two cases of genaric trans fluid is about $25.00. A new trans filter and gasket are about $25.00. A new transmission is alot more. Ps; use Dexron 3.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 12-01-2004 at 11:20 AM. |
I'm using Dexron 3/Mercon fluid. It's a new tranny direct from Subaru in Japan. I just do primarily long stretches of highway driving with no cooler. Installing it as I type this.
BTW I work at a speed shop so I get all sorts of auto parts/fluids/accessories at cost; i.e. my case of tranny fluid was like $7.00. Not to brag or anything . . . |
-Chike
This was the 2nd tranny fluid change in 3 days. Should be good enough until I can get the cooler installed, then I'll do it again, and again, and again, until I have no more fluid lying around. I only got about 3.5qts out of it the first time, I'd wager that I got almost 5 or 6 this time since I dropped the pan and did the filter.
Will keep y'all informed as to my car's status. |
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Well maybe for you its available. But for us here in the States I have only seen dexron III. I'm thinkin its the same thing but probably better.
