Brake leak found
Well, my brake light has been coming on more often now, and I need to fill the reservoir more often than I feel comfortable with. I hadn't noticed any fluid anywhere before (probably because the leak was so gradual) but it's starting to accumulate. This is what's leaking:
It is just in front of the passenger rear wheel. The inside lines under the back seat are dry as a bone. There is no fluid on the calipers or the lines connecting to them, and the lines look fairly new too. I will be taking it somewhere this week. Even though I'm pretty mechanical and good at fixing things, I don't want to mess with my brakes. Is this going to be an expensive repair? :[
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Brake leak found
bump, anyone?
Sorry, It is
Keith |
To do it correctly, yes, unfortunately. The correct way to replace that line is to drop the fuel tank (which means rear diff, exhaust, driveshaft, etc) and either replace at the closest fitting or cut/flare and start a new line. Not a cheap repair.
Now, that being said, I believe my car once suffered a similar failure and was repaired without dropping the tank. It looks like someone fed the line through however they could and just bent it into place. It isn't pretty and I don't like it much, but my brakes have worked perfectly for the 5 years I've owned the car.
I just had the entire rear end disassembled about a year ago to replace my fuel lines... I really don't want to do that again. The place I take her to is very honest, and they would have noticed if the piping that's hidden was bad and they would have replaced it. Could I just replace the broken part and rig it? It doesn't have to look perfect.. I just want my brakes to work... Do you have any pictures of it?
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. Last edited by B 4 You; 05-29-2012 at 08:14 PM. |
The labor should be about the same as what they charged for fuel lines.
