Clock and Climate Control Not Working
After installing an FM modulator for my ipod, I noticed that my clock and climate control dont work. I read somewhere it could be fuse #20. Can anyone tell me which specific fuse #20 (Im assuming its on the kick panel) that is?
Thanks. Larry |
Re: Clock and Climate Control Not Working
Fuse 20 is in the kick panel. Bottom row, next to last fuse on the right.
The owner's manual says it controls the cooling fan. The clock fuse (25) and the A/C system fuse (33) are both located in the fuse box under the hood. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-23-2012 at 02:44 PM. |
Thanks for the info. I checked those particular fuses and they looked fine so I just pulled each one in the kick panel. Turns out that it was the one in the top row that says "Cigar" thats a 20 amp fuse. Put in a new one and it works fine.
Larry |
So I guess I'm not the only one with this issue. I ripped off the connector from the cig lighter and I pulled apart the connector inside the elbow of the driver's side visor. I then plugged back in the fuse and everything worked. The fuse had never blown. I am suspecting either the freshly damaged lighter or the visor was partially shorted, drawing lots of current, but not enough to blow the fuse, and this caused a brown out of sorts for the other components.
We should be happy to have such few, easily fixed electrical problems.
