Loose strut nut
I have had a rattle coming from the rear drivers side and just checked the nut that comes into the interior where the speakers are. Sure enough the left rear nut (17mm) was loose. The right side was tight. I turned it but it did not tighten. Just spinning the whole thing. I assume I have to hold something under the car to get it to tighten. Anybody had to do this? When I first had my Koni and lowering springs put on I had to take it back and they tightened it but not sure how exactly how he did it. That was years ago. I was ready to order new rear upper mounts. Maybe I don't have to. I want to get this tight and check the noise again. Any advice on this appreciated. Thanks.
Mike
95 Pearl Blue L |
Re: Loose strut nut
On both stock struts, and Koni's you have to hold the strut piston shaft from turning with an allen wrench.
Re: Loose strut nut
I had a handle welded to a socket so I could get an allen wrench through he center. I guess a vice grip would work for a handle in a pinch but after removing the rear shelf, I wanted assurance I wouldn't have to do it again.
Re: Loose strut nut
For $20 this makes it easier;
http://www.harborfreight.com/21-piec...set-67974.html Plus it's handy is other places also, and it's not too hard to find a 20% coupon for HF.
Re: Loose strut nut
Got one from sears for $40
Re: Loose strut nut
Did you get the "Gear Wrench" brand? Ben has those, I think they are nicer than the HF ones.
Re: Loose strut nut
Re: Loose strut nut
The sockets have wrench flats on them, much like a spark plug socket. The ratchet is a ratcheting wrench of that size.
