#91
Re: Mid Engine SVX concept.
I think MRT summed it up well in this artical from there web site when they talk about suspension.
"Subaru has tuned the suspension settings of a standard WRX to cater for a wide range of drivers. This means handling characteristics have been set for the lowest common denominator, or drivers with dubious skill levels, and those that demand ride comfort over performance." Kind of changes the thinking a bit. I need to do as Matt suggested in the start then worry about it later. I can model the suspension behaviour on the 3D cad later Tony http://www.mrtrally.com.au/performan...x_book/P96.pdf
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#92
McNeil Racing's Mid Size T-Style fiberglass/carbon fiber dash are within spec of our stock dashes. I plan on using them for my car. http://www.mcneilracinginc.com/off-r...berglass/dash/
For speedglass for the svx, talk to Talor Percy's http://www.percysop.com/racing_windshields.html Contact Patrick at 816-765-5011 here in the states. They built a new facility just for the speedglass (aka lexan) and can get you a custom set with quick turn around. you will need to provide a set of svx glass for them to make the copys from. However, the stock SVX glass is not all the heavy. Rear Glass: 21 lbs. Rear Side Upper Glass: 6 lbs. each Rear Side Lower Glass: 3 lbs. each Front Side Upper Glass: 6 lbs. each Front Side lower Glass: 6 lbs. each. Id just replace the flat, roll down sections and leave the rest. Less the front windscreen there is only 63lbs worth of glass on our car. Honestly, I expected it to be more than that. At most, with lexan you would only be shaving off perhaps 30 lbs. Not worth the $800+ (usd) it would cost. Not to mention the cost of new weather stripping ( nearly $500 from Subaru ) and install. Last edited by smc; 10-23-2012 at 10:19 PM. |
#93
This is what happens when you goto town on the mods: http://www.youtube.com/watch?v=OOP3_1TsXs4 http://www.youtube.com/watch?v=BAUG7w_GtmU |
#94
It also provides some rear wheel steer. On a left turn, as the body rolls to the right, the strut compresses. The trailing arm moves through a shorter ark so, as the wheel goes up, the arm pulls it forward, causing the wheel to toe in, to steer the rear into the corner. The arms position on the car now, is designed to suit the car as it is. With an engine in the rear, the amount of rear steer has to change to suit the new conditions. Lengthing the arm reduces the change, and changing the height of the front pivot, changes the rate of change to wheel movement. Harvey.
#95
Left brain tells me that the outside wheel goes back, the front of the wheel turns out and that enable the front of the car to turn in more thus reducing the understeer in the car. Back of car wants to swing around, How does that sound for a load of bull. Even if I have it slightly wrong in behaviour what you say the reason its there now makes sense Harvey. Thanks. Tony
#96
This happens with a fair bit of body roll, so the load is on the outside wheel, that does the steer. Harvey.
#97
Did some test work with the new sub frame design and I think the pipe won't work as the the main engine support. The engine load is down twards the ground and the pipe wants to flex, I will change the beams to two rails 75mm by 50mm by 2mm wall. In this way I should get a more rigid engine support.
Anyone have a opinion???
#98
We are right but wrong Harvey,
The wheel DOES NOT toe out or in. I have been straching my head thinking if the wheel toed out or in there would be problems. If the wheel toed out the car would become unstable in the ass. So what the smart buggers do is they move the wheels foward and back but maintain the parrell between each wheel. the centre line of the two wheels changes so if I am going around a left hand corner the left wheel lifts and it moves forward, the two laterial arms are the same length so they don't change the angle of the wheel just move it forward. THe left hand wheel raises so moves back staying parrel with the other side. Now the centre line between each wheel is off line with the angle of the line of the car. in short the two back wheels are pointing towards the left causng the back of the car to want to go left, net result reduced understeer. Sounds interesting. So if this assumption is right what more can we do to make it better? Tony
#99
Tried farming with RHS and it didn't happen, went back to pipe. Settled on final design and also designed the jig to hold all the parts in place while they are being welded. As you can see the suspenion mounts can be moved and adjusted. The overall height of the sub frame relitive to the support point on the chasse can be changed as well.
Here it is in 3d pdf, the main frame that goes in the car is the red part. We will start cutting the set for the jig this afternoon. Tony
#100
Has anyone weighted the rear boot and the front bonnet. Also what about the front and rear bumper bar?
I am trying to figure were the total weight of 1,600kg's of our car comes from and how much can be removed. Tony.
#102
Ditto! Nicely done. Tony! The Acrobat software has come a long way regarding visualization. I take it you're using a high end CAD program and saving the file as a 3D pdf?? Are the green pieces just your welding jig and the blue representing the mounting points on the SVX frame?
Thanks. Bill
#103
Tony, I know just about everything has been weighed in the past. OT can probably pull everything out of his head. I'll see what I can dig up. Cheers Bill
#104
Tony,
Here's what I was able to dig up after a little searching: Driver seat (leather with electric controls)- 68 lbs. Passenger seat- 49 lbs. Rear seat bottom- 13 lbs. Rear seat back- 24 lbs. Factory type spare tire- 28 lbs. Factory wheel complete with tire, balanced and inflated- 47 lbs. (Note only a 19 lb. difference between those meaty real wheel assemblies and the goofy temporary spare. Those wheels are fairly light.) Standard type battery- 31 lbs. Back glass- 20 lbs Rear 1/4(stationary) glass- 5 lbs Rear 1/4(moving) glass- 3 lbs Rear window regulator- 4lbs. Front(moving) glass- 8 lbs Entire AC system (less ducts)- 30 lbs. Bumper core- 28 lbs. Entire sunroof assembly (including motor, cables, tracks, wiring)- 29 lbs. Hood- 46 lbs. Entire trunk assembly (including lifters, hinges, lights, reflectors, and wiring)- 37 lbs. Front fenders - 10 lbs/each Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 10-29-2012 at 05:38 AM. |
#105
3580
3580 lb car - 23 lb drivers seat swap - 13 lb front bumper exchange - 20 lb rear bumper reengineer - 14 lb lighter wheels (16.5 ea) - 33 lb spare tire, jack and tools - 8 lb trunk carpet + cardboard - 39 lb exhaust system +220 lb driver + 35 lb gas 3685 lb car The stock headers weigh 18 lbs, the pipe from the headers to the muffler weighs 50 lbs, the muffler weighs 35 lbs, 103 lbs total. My system, from the home made headers, cherry bomb, 3” tubing + afterburner + polished tip weigh 64lbs. 39 lbs savings So far 150 lb savings. Note; 4 lb savings on underdrive pulley offset by added weight of adjustable FPR I cut out the bracing from under the hood, 11 lbs.(the hood was a spare) Not recommended for the street. Took off the iron bracket for the ac belt adjuster, 3 lbs. Note, if the complete front bumper support was removed, it would be a 26 lb loss. What size are your boots?
