Old 10-16-2008, 04:56 PM
tigersvx's Avatar
tigersvx tigersvx is offline
1992 SVX WHITEPEARL
too much engine oil for about0.8litre
does any guru knows that if i overfilled my engine for about 0.8litre of engine oil,what harm will it does to my engine,or if it ok,what should i do? thanks...
1992 SVX whitepearl 129,000km
2005 MAZDA3 red 38,000km
2001 HYUNDAI XG V6.3000
2003 TOYOTA PREVIA
Old 10-16-2008, 10:08 PM
Re: too much engine oil for about0.8litre
Put car on jackstands. Remove oil drainplug. Quickly replace. Check level. Problem solved.
You don't want to have too much oil. A little excess won't hurt anything, but the SVX is already an oil pig, needing 6.5L of oil, so now you're at 7.3 or so, which is a hell of a lot. When you overfill the oil too far, it will get to the point that the crank is splashing in it as it turns, which will foam it, reducing effectiveness (air pockets all over the place).
Old 10-16-2008, 10:46 PM
If you don't want to get under the car you can just poke the dipstick in and out, wiping it off between pokings until you have removed the 0.8 liters.
Old 10-16-2008, 11:13 PM
Note, this procedure may take a little while longer. 7 or 8 years longer.
Old 10-16-2008, 11:22 PM
tigersvx's Avatar
1992 SVX WHITEPEARL
i thought svx use 6 litre as in manual?my level shown just half an inch over the full dot,right on the broken dot,last dot on the side on the dipstick,,,,below it has two middle dots,one is low,one is full,right,so mine is half inch above full,,,,my mechanic use two 4 litre oil,one used up,the second left about 1.2litre,so 6.8litre used,,,,if as u said svx needs 6.5,,so just over by 0.3litre,should not be a problem????and i run 500km now,it seems fine...
2003 TOYOTA PREVIA
Old 10-16-2008, 11:24 PM
tigersvx's Avatar
1992 SVX WHITEPEARL
yeh,,,,i try do that,,,it did take me 7-8 years,,or longer.....
2003 TOYOTA PREVIA
Old 10-16-2008, 11:28 PM
That's not too bad then, I've usually put about 6.5L in during oil changes, depending how long I let it drain for.
Old 10-16-2008, 11:32 PM
tigersvx's Avatar
1992 SVX WHITEPEARL
thanks a lot,,u know if im in thailand,at a gas station,they have this oil change machine they use to suck up the engine oil through the dipstick hole,i can just spend 2-3 dollars to have this fix,but in new zealand,anyone know if they have this machine,where?benz,bmw they all change oil by suck up.....no plug draininganymore..
2003 TOYOTA PREVIA
Old 10-16-2008, 11:39 PM
tigersvx's Avatar
1992 SVX WHITEPEARL
thanks,i guess itwont be too bad then,,less me some worry,yeh,last time my mechanic use about 6.5 litre too,cos two bottle of 4 litre each,left with a little less than half on the second one,,each time it was more than 6 litre...
2003 TOYOTA PREVIA
