Old 02-21-2013, 03:42 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
lower control arm replacement
does anyone know if the lower control arms are a pain to replace? i just ask because i called for a quote to replace them and told the guy i had the parts and he quoted me $350 that seems like a lot to me considering it only looks like 5 or 6 bolts to take off and put back on...also i looked for a "how to" but didnt find one...is there?
thanks
this is for the front not the rear btw
Jared
1992 dark teal SVX LS
Old 02-21-2013, 05:05 PM
dragoontwo dragoontwo is offline
Re: lower control arm replacement
It doesn't look very hard or complicated. I have not done it so I can not say for sure. It will probably come down to how corroded everything in there is.
'92 SVX LS Pearl White - 6mt
Old 02-21-2013, 05:13 PM
it is all covered with oil so not very rusted at all just greasy
Jared
Old 02-21-2013, 05:17 PM
^ What he said. It's not very difficult as long as none of the bolts are seized.
Once you're underneath it, it's obvious enough what to do that a how-to is not really necessary. The only kinda tricky thing is getting the ball joint stud out of the knuckle.
Actually one more thing that's important is that to get to the rear bolt holding the control arm to the subframe, you have to take off a bracket that holds the subframe to the body of the car. Only take the bracket off one side at a time, in case the subframe could fall or shift without both of them on.
Old 02-21-2013, 05:29 PM
well ^ this part sounds a little scary lol
when you say one side at a time you mean drivers side and passenger side right? i was hoping to get this done all on a Sunday cus it's my daily driver.
Jared
Old 02-21-2013, 05:35 PM
I don't think it would actually fall, but I'm not 100% sure, so just to be safe. Yes, I mean driver's side and passenger side.
Old 02-21-2013, 05:46 PM
alright cool thats what i planned on doing anyway cus only the drivers side is bad right now so depending on how long it takes i may only do one side then next week do the other thanks for the help!
Jared
Old 02-24-2013, 01:32 PM
Wikedjuggalo's Avatar
Rebuilding
Why do you think it needs to be replaced? Its not difficult if I recall. Takes time and patience.
Old 02-25-2013, 11:18 AM
the bushings are shot on the drivers side
Jared
Old 04-15-2013, 09:18 AM
so i have run into kind of an odd issue...last night i replaced the lower control arms on the car with some newer used ones until i can get the bushings in from whoever has them i drove the car last night and this morning and i still hear the same knocking noise that i did before BUT the car is driving much better (for now)...the wheel doesnt hop on shallow right handed corners anymore but it still sounds like something is hitting the bottom of the car every time i go over a bump....
i fixed what i was feeling but not what i was hearing HELP any ideas lol
Jared
Old 04-15-2013, 09:23 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check your struts if they are leaking.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-15-2013, 09:32 AM
im pretty sure it isnt those because it is a different feeling than when the struts went bad plus i replaced them less than a year ago on the front that is...
i know the suspension in the back is getting real bad is it possible that im hearing the rear suspension?
now that would be really be something because i would have been willing to bet money that is is coming from the front
i went and checked and they look fine no fluid on them
Jared
Old 04-15-2013, 11:48 AM
Strut top mounts? The front ones have a bearing that can get worn and start to rattle.
Old 04-15-2013, 01:42 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
End links can rattle too. I'm replacing mine Wednesday
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-15-2013, 01:51 PM
Another good suggestion. And they can be replaced for cheap too: http://www.ebay.com/itm/2-FRONT-Sway...-/220445397586
