Old 04-24-2013, 10:56 AM
Need a Part Number for Power Steering Pump
Car is at the shop, mechanic says it needs a new power steering pump.
Does anyone know the part number for the pump? I can't find it...
I am looking at this:
http://www.subaruparts.com/diag/?mod...ategory=346-A1
Which one is the pump?
Is it the piece that says see figure "348-A"
Which leads me to "Oil pump" 34411PA001?
Is this the same thing?
http://www.autopartswarehouse.com/se...teering%20Pump
Old 04-24-2013, 01:09 PM
Re: Need a Part Number for Power Steering Pump
http://www.subaru-svx.net/forum/showthread.php?t=60770
Something about teaching a man to fish...
Old 04-24-2013, 01:52 PM
Anyways, I just need a confirmation that this is the "power steering pump" that I need before I order it...
http://www.autopartswarehouse.com/sk.../A1215882.html
Old 04-24-2013, 02:03 PM
Oh, sorry, didn't see the part of your post below the picture, and thought you just needed the part number.
From the pictures, it looks like the pump you linked is correct.
Old 04-24-2013, 05:01 PM
oab_au oab_au is offline
The pump is different for "road speed" and for "engine speed". Make sure you order the right one.
One Arm Bloke.
Tell it like it is!
Old 04-25-2013, 02:02 AM
I have a 92 LSL (X35 vin), so vehicle speed sensitive.
I don't see 2 different pumps listed anywhere. Every site I have check says 1992 all submodels all engines.
Is there actually 2 different pumps? All I can find is the 34411PA001 one.
Old 04-25-2013, 12:28 PM
On page 170, it lists 2 different part numbers for the pumps, one for LSI and one for the others.
Old 04-25-2013, 01:51 PM
IF you have an LS-L, LSi, (leather, touring package) you have the electronic vehicle speed-sensitive power steering.
All other models came with the engine (RPM) sensitive steering.
Vehicle speed sensitive is much more accurate and responsive for precise driving.
Old 04-25-2013, 05:18 PM
The pump is different for the two, the pressure control valve is different. The RPM one has a three stage flow valve in it, to control the pressure, as the rpm rises. The Elect. has a single stage valve, in it as the solenoid is used to control the pressure.
One Arm Bloke.
Tell it like it is!
Old 04-25-2013, 07:22 PM
That link tells me HTTP ERROR 400. It wont pull the page up..
After going through another 60 pages.. I found this on page 230 of the 92-94 book:
After searching for the 2 parts with dots under 92, I find that they don't exist.
34411PA000 has been superseded by 34411PA001
34411PA010 has been superseded by 34411PA071
Which is probably why the mechanics computer kept telling him the part is not available...
Can someone confirm that the LSI pump for 94 and Later #34411PA071 is correct for a 92LSL??
Onto the next half my problem....
Searching autozone for either of these part numbers cross references me to the same pump.. Duralast 5242...
34411PA001
34411PA071
How can the duralast pump be the same pump for both part numbers if they are different?
Old 04-26-2013, 09:18 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
too bad you dont have an LS cus i have a brand new power steering pump from Subaru im trying to get rid of
Jared
1992 dark teal SVX LS
Old 04-26-2013, 10:32 AM
The 94 LSi pump and the 92 LS-L pump should be the same. Vehicle speed sensitive.
I seem to remember a newer design for the high pressure P/S hose in later years. Just a minor change. Someone here can clarify this. They are all the newer design now.
Old 04-26-2013, 10:56 AM
Yes, the lines are interchangeable. So a speed sensitive from a 92 will also work on a 94+ speed sensitive with the modified/new design line.
Old 04-26-2013, 11:18 AM
Blacky Blacky is online now
Am I the only one besides Lookin4SVX who finds this thread extremely confusing. Too many different apples and oranges are being thrown into the blender.
Old 04-26-2013, 12:53 PM
Am I the only one besides Lookin4SVX who finds this thread extremely confusing? Too many different apples and oranges are being thrown into the blender.
SPEED-Sensitive Power Steering Pump
1992 LS-L
1993 AE
1994 - 1997 LSi
ENGINE-Sensitive (RPM) Power Steering Pump
1992 LS
1994 - 1995 L and LS
1996- 1997 L
ALL high-pressure P/S hoses (either old or new design) fit ALL pumps. Only the newer redesign hose is available new from Subaru.
Basically if your car came from the factory with leather, you have speed-sensitive.
