a/c removal
I'm thinking of taking out the a/c except for the evap.I'll cap the ports on the firewall. I use the car in the summer and it doesn't really get that hot here so I never use it.Question is, will this end up setting codes or any other nonsense and should I just leave it in? I can't think of any reason why this might be a bad idea but I don't know enough about it. Has anyone done this? Thanks Dennis
Re: a/c removal
Plenty have done it, no problems reported from what I remember..
But it is a really really dumb thing to delete.. It lowers the resale value and only drops about 80lbs.. Yours don't work? Might be an easy fix.. Mine doesn't work either and summer here is HELL!!! (in MD) Needless to say I plan on fixing it this year..
Re: a/c removal
Makes no sense to do away with a system that is needed to make other things perform correctly. Just my 2 cents worth Keith |
Re: a/c removal
I haven't had A/C in my car for quite a while. There's a massive leak in the condensor, so I simply cut the A/C belt. (less useless drag on the engine). I haven't had any codes and the climate control still performs just fine. The windows de-fog just fine. I'll probably get around to removing the entire system this summer to cut a bit more weight off the front end.
Re: a/c removal
It's a bad idea that you will come to regret if you keep the car - and especially if you try to sell it.
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
Re: a/c removal
It's been well over a year since the belt came off, and I never had A/C to begin with...no regrets yet. It doesn't get hot enough here to make me want A/C THAT badly. Open windows and sunroof gets the job done.
Re: a/c removal
We don't get as cold as you. Texas can still get as low as the 20s (F) but its humid as well. Of course, we also get really hot (109+) soooo AC is a must down south.
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
Re: a/c removal
The weight lost by removing the compressor is not substantial enough for it to be a logical reason unless you are installing a super charger and need the room for the extra pulleys or you are trimming weight from the whole car (removing all interior, getting a lighter battery, etc) to be a race car. If you want to cut some real weight without losing features, try getting a fiberglass hood from svxfiles (our stock hood is like 41lbs, his is 19lbs) or getting lighter wheels (I think ours are like 28lbs each and I think the 2006/2007 STi wheels are like 17lbs - which is what I went with).. There are even lighter wheels out there, just find some that are 5x114.3 and have an offset somewhere around +55..
