Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 10-19-2012, 04:31 AM
Double the Joy
I recently came across a shop selling Strong Arm products locally.
Since shipping from the US is not always a viable option, I had to "improvise" with what is available. They don't have the SVX struts in stock. They simply bought a "shipment" of Strong Arm from the US and are selling it in pieces in my country. They are not even dealers for it.
Anyways, since my future project involves adding a [top secret] wing project which will add a few pounds here and there, I thought to fab something more durable for my car. After 80 hours in trial and error, I made it!
It works perfectly for my need
Old 10-19-2012, 08:51 AM
Old Fogey
Re: Double the Joy
Nice job Danny! What happens when you hit the release on the stock trunk with the struts doubled up like that? Does it pop up like a speed-brake?
Glenn
Old 10-19-2012, 11:26 AM
Re: Double the Joy
Glenn
Hello Glenn,
Unfortunately no. The trunk hinge system of the SVX does not allow the trunk to pop up as you think. But once it is half way, you simply.... cannot hold it from opening all the way
Old 10-19-2012, 12:09 PM
Re: Double the Joy
Originally Posted by SilverSpear View Post
FTFY .......
Old 10-19-2012, 12:39 PM
Re: Double the Joy
FTFY .......
10x
Old 10-19-2012, 12:41 PM
Re: Double the Joy
Seems like they open more smoothly than mine (the ebay lift support depot ones).
Old 10-19-2012, 04:40 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Re: Double the Joy
Care to share your design for the brackets (I'm assuming you made them yourself), and the specs on the struts? I may copy you if you don't mind
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 10-20-2012, 01:22 AM
Re: Double the Joy
I don't mind sharing the measurements, but as a note you will need:
- grinder with cutting and grinding discs;
- welding machine;
- 13mm bolts, nuts, washers, locks;
- impact drill or drill bench;
- bench holding unit (whatshamacallit);
- 4mm iron plates;
- paint;
- some skills...
Just gimme some time, I am still testing the entire system. I might even make it better...
Old 10-20-2012, 03:39 PM
SVX8588's Avatar
Re: Double the Joy
- welding machine;
- bench holding unit (whatshamacallit); VISE?
- 4mm iron plates;
- paint;
- some skills...
Thanks, I look forward to doing this; my trunk may as well not have any struts the way it is now!
And I have done a bit of fabrication before
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 10-20-2012, 05:17 PM
dbarnblatt's Avatar
Re: Double the Joy
I am going to give this place a try. Not only do they rebuild and recharge spent struts, but they also can adjust the pressure of the strut to accommodate different weights.
http://www.lstechnologies.ca/recharging.html
I know a few Ferrari guys who have rebuilt their Boxer engine cover struts using this company.
Old 10-20-2012, 05:49 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Double the Joy
why would a double strut be necessary, how often do you open your trunk, that a single strut wouldnt be sufficient
1995 POLO LSI 76K MILES SOLD
Old 10-23-2012, 12:55 AM
smc smc is offline
Re: Double the Joy
He's fabricating a new fiberglass rear spoiler, which will add a few lbs to the trunk lid. The stock single struts are barely enough to lift the factory lid and wing. Let alone an additional 7 lbs or so.
Old 10-23-2012, 01:19 AM
dbarnblatt's Avatar
Re: Double the Joy
I think a stronger recharge on a rebuilt set of single struts would suffice.
Old 10-23-2012, 03:22 AM
Re: Double the Joy
Close... I will be repositioning/lowering my current wing and adding a mechanism inside the trunk lid...
Old 10-23-2012, 09:27 PM
smc smc is offline
Re: Double the Joy
Hehe. Not so Top Secret now
