WTB: Front control arms
I'm looking for a set of front control arms in good condition to use for my sway bar end link project. As near to new condition as I can get, I don't want to spend a whole ton of time cleaning the metal so I can weld it.
My plan is to weld a small bracket onto the control arm so I can use the rear endlink from an '05 Outback. By not having the endlink attach to the strut as the stock SVX does, I hope to be able to fit STI or Forester suspension. Here's a picture of the idea:
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 11-18-2007 at 01:52 PM. |
Do you still need these ?
I have a parts car with these. No rust. Lemme know
Yup, still in the market. Let me know how much you'd like for them with shipping to Canada, area code K2J 5E3.
I like the idea... I would rather find a way to mount the STi hub on there though. not only will you have to grind down the SVX hub to get the thin strut braces on, with the STi hub, you can mount Brembos
Tom |
Has anyone tried fitting an STi knuckle? If the STi suspension were used the only thing that would need to be made to fit is the ball joint, although there isn't anything "only" about that. The steering links, well those are just threaded tie rods. They can be made to work.
Now you're thinkin... Only one way to find out Tom |
