I broke my speedometer when I pulled the dashboard
I changed out my bad heater core this weekend with a used one (thanks again benebob/hocrest)
This requires removing the dashboard, console, dropping the steering column, and pulling the steering support beam back. Yes, it sucked. Got it all back together, blew out the air bubbles, and I have heat again! But - I no longer have a speedometer reading Feeling stupid, I went through the whole process of removing everything and checked to find out what I left unplugged, pinched, or otherwise screwed up. Didn't find anything. Wiggled all the connections I had played with just to make sure. Put it all back together and still no speedo. The rest of the instrument cluster seems to work. Not sure on the gas gauge - time will tell with that. Cruise control no longer works either. Just feeling stupid. I guess a used cluster will be my first (maybe cheapest) line of troubleshooting. I hate to lose my mileage count (245k)
Try to check the speedo part of the dash... maybe something is stuck or cut in the wirings.. check the back of the speedo and its related pins in the dash.
I pulled the speedo cluster about 5 times and drove around each time. I even tried leaving the screws loose and wiggling it a little while driving. No luck. I took a good look at the wire tape and couldn't see any that were broken or anything. I also checked all the tabs on the sockets that it plugs into and they were all in good shape and bent out far enough to make good contact.
It was pretty frustrating. And all I have left in the fridge is corona light and a few lagers. And it's no beer sales sunday in SC
That's a crime!
Don't panic. It is very likely that fuse No. 15 is blown, as this fuse covers both the speedometer and fuel gauge circuits.
P.S. You are very lucky that I checked your thread, because the heading in no way describes the problem and it should be within the technical section. Refer sticky covering this issue!
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 10-21-2007 at 05:11 PM. Reason: P.S. Added |
I checked all of the fuses quickly earlier today. I'll go out now and pull each one again to double check. (I blew up my test light a while ago) Since this thread is turning more to tech help than just me drowning in my sorrow I'll go ahead and move it a and re-title it.
To make matters worse, I found a bottle of Genesee Cream Ale in the back of the beer fridge.
Drinking it now.
Checked all the fuses - they all are complete.
I really need a test light to verify they are all getting power though. I don't see one labeled as anything related to speedo (maybe meter?) and can't figure out which is # 15 on this diagram but I checked each one for a break. All of the fuses under the hood are complete also.
