Brake line question
I pulled the ABS unit out of my car and have a question now that I am starting to redo the hard lines. I have installed a non-abs master cylinder and running the two front lines will not be that big of a deal, but my question is can I just tie into the proportioning valve mounted on the pass. side strut tower for the rear?
Re: Brake line question
Anybody? I am getting itchy to drive this and have it ready for the pumpkin carve meet in October..
I know nothing about it, sorry ,
please let us know how you sort it out
Its coming!
Hey Everyone
Had the 92 svxlsi up on jack stands for a year, Driving a 04 Forester XT but its time to get the svx up and running again. Found a leak from the r/r inbroad of the sub frame and its runs over the sub frame, is there anyway to remove it easily? Can the pipe be removed without dropping the sub frame? I have the FSM but all that shows is the pipes and hoses, it does not tell how to remove it from the car. Any info on this job would be a great help
_______________ 92svxman & Freida the co-pilot. First 92 Claret(flat color,IMHO) Two 92 Teal(much nicer color) 5 Speed pending, from 93 Legacy Turbo 4.11 Tranny/rear diff. May go for 3.90 Claret 145K Underdrive Pulley from Newbies2005 New timing belt new radiator new water pump new timing belt cover New headlights and harness Replaced exhaust (with stock) Life on the road who could ask for more |
You could ask LetitSnow, as he has Tom's old car which has the ABS deleted.
1991 SVX L JDM |
I have the non-ABS MC already and have it installed. Did Tom use OEM non ABS lines when he pulled the ABS system from his car?
How much does the ABS unit weigh?
Estimating from the ones I've lifted around, almost as much as a battery, about 25-30 lbs. The reason for eliminating it is partially for the weight, but more to eliminate the risk of the problem Tom had that caused him to get in a little fender bender when the ABS unit acted up...
What happened to Tom?
There is no ABS on The Racer now, so I'll take a look and call you, Bobby.
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
