Help! Replaced the 4eat and don't have any ATF flow.
What are the possibilities here? This is a Leg tranny into a Leg. I move the gear selector and the car doesn't do anything. I disconnected the ATF lines from the tranny and there is no flow with the engine on. If the torque converter drives the ATF pump and we know the TC is spinning, is it possible the circlip just popped out on installation? I suppose it could be a dead pump, but are there any other possibilities? I suppose there is no way to get this to work without pulling the tranny again. Has this happened to anyone? Thanks.
Stephen |
I'm with Harvey...no pump, no flow...
-Bill
I didn't see any ATF in it when I seated it onto the tranny. |
is it making noise?? I remember when I didn't line up the TC right for the first time.... Crushed the oil pump to death I hope you didn't do the same
Tom |
Thanks for all the input. I read several writeups on seating the TC so I'm pretty sure I got that right, but not 100%. It never made any noise like it was trying to do something, when it was running. I didn't pull the pan and look at the internal filter. I already yanked it this AM. At least I'm getting quicker, I got it out in an hour and a half this time. I'll check it out and see if I can find anything. Of course I may be installing a spare 5 spd in it while I'm checking out the AT. We'll see. I really want to have a good 4eat in this car, but out of the five 4eats I've had in my Subes, not a one was worth a crap.
Stephen |
If it locks up it was not seated. I have seen some wrecking yards pull off the trans pan, and remove the filter, just to make sure you install a new filter. AND, some wrecking yards leave a plastic baggie in the pan with the pan bolts in it! We had someone on the Network have a dented trans pan, that restricted the oil flow into the filter pickup...
Well......................Uh...................mmm m..................Ok I guess I didn't have it in all the way. DTOH!!! I sat there and spun it around for a couple of seconds and gave me one extra clunk that sat it down another 3/8 or 1/2" so that the flexplate side of the bolt tangs are exactly flush with the bellhousing mating surface. Before, the TC side of the tangs were flush. You live and learn I guess.
Now the question is: Do I dare just slap it back in like it is or is there anything I need to carefully inspect first? Stephen |
check the end of the pump drive and make sure it is not broken or ground down. Also might want to check and be sure that the pump isn't messed up. Take a light and look down the input shaft.
Tom |
