Old 12-17-2007, 01:06 PM
cruisen_15's Avatar
cruisen_15 cruisen_15 is offline
build my own s/c
ive been looking at my leaf blower, its a 200mph one and gas.. its way of spooling up air is exactly like a turbo... im going to buy a 225mph electric one, shave it down, put a air filter on and hook it up to my battery, probably a yellow top... i will tell anyone if it works... , any precations i should keep in mind?? if i do... just maby get 5 or more psi.. then will i have to get an impreza f.p.r so it will mix better??
Old 12-17-2007, 01:17 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
Originally Posted by cruisen_15 View Post
but its people like me who have built turbochargers and supercharges, ect....
Don't get this part of your post...
but anyway, can you really get it small enough to cram it under the hood? I don't want to see you waste your money but I'm also sortof curious to see what you end up with. You may need a high amp inverter for that idea.
If it doesn't work it'll be hilarious to try to return the blower all hacked up
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 12-17-2007, 04:35 PM
cruisen_15's Avatar
well the blower is only like 20$ off of ebay and its craftsman.. i also have a good power invertor i could use instead...
Old 12-17-2007, 05:35 PM
SomethingElse's Avatar
word words wording
Dude! What are you smokin?
What kind of blowoff valve are you going to use?
Eric
Old 12-17-2007, 05:38 PM
Seriously man, no offense but your ideas are off the wall, what's your reasoning/theory behind all of this?
Old 12-17-2007, 05:57 PM
Speedklix's Avatar
c'mon guys.
It may seam ridiculous, but it is trial and error and the things you learn along the way. Please don't take offense Myxalplyx, but I'm gonna use you as an example. He had a rough start with his ideas, but he ended up with a design that showed some real impressive gains in the end.
-Mike
[SIGPIC][/SIGPIC]
Old 12-17-2007, 06:11 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
This has been tried, and failed, a million times before on countless other vehicles. It has been shown that you can alter a motors VE with it, but in reality gain no appreciable power.
The problem lies in the blowers. They either flow lots of volume at no pressure, or can build 1-2 psi at negligible volume(less than 150cfm). Neither suit an engine at all.
The only way you're going to see anything appreciable is to make this using a brushless motor/controller system using a 20-30K rpm motor with about 2-3hp and build it onto an actual turbocharger compressor housing with a compressor wheel that can both build pressure and provide flow. This has worked before, but the mass of required batteries to make the system work and their weight penalty far outweigh the 10-15hp gain that was noticed.
I'd feel better about you welding turbochargers directly to your OEM headers than proceeding further with this.
Old 12-17-2007, 06:41 PM
gsodonis's Avatar
gsodonis gsodonis is offline
I can just see it now!
http://www.youtube.com/watch?v=xwkSr...eature=related
Old 12-17-2007, 06:43 PM
cruisen_15's Avatar
this is a leaf blower setup...http://youtube.com/watch?v=1nBowIlXef0
Old 12-17-2007, 06:49 PM
Is that Civic even running? I can't hear anything, and if it was running I would expect to see a slight negative pressure on the gauge when he blower isn't on.
Old 12-17-2007, 07:03 PM
the thing i do not understand about this whole setup is that everything else is stock, namely the MAF, the MAF can only read a certain amount of air volume so pushes more through will not provide any benefit, not to mention the fuel is limited as well and the stock cams which hinder breathability...
Old 12-17-2007, 07:38 PM
Turbone's Avatar
Turbone Turbone is offline
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
Hey Cruisen, think I spoted your car in Puyallup the other day.
Does your have a Supra spoiler on the rear deck?
Post some pics of your SVX, I think everyone else has.
Verified Females
Old 12-17-2007, 08:12 PM
cruisen_15's Avatar
turbone, nope that was not mine, the guy doesnt belong to svx forums... he lives very close to me, i havent met him yet but we've noticed eachother driving svx's and just starred lol..., o btw i believe he has a 6 speed swap
Old 12-17-2007, 08:34 PM
Turbone's Avatar
Wow, a 6spd swap and not a member here
Still want to see pics of your car
Verified Females
Old 12-17-2007, 08:39 PM
cruisen_15's Avatar
i posted pics of my car just now in the svx babble...
